That darn yellow light is on again!!!
/ That darn yellow light is on again!!! #1
dougfollett
Olympia, Washington.
Yanmar 1500
It's me again with the Yanmar 1500 with the front loader. I was working around the homestead today trying to tidy up some areas that were kind of lumpy. Nothing real serious. I had already done most of the work the week before with the neighbors JD. I just wanted to smooth things out a bit so I droped the bucket and drug it backwards. I also scraped up several buckets of debri as well as pushed some piles aside. Nothing real strenious as far as I could tell. I did bog down a couple of times when I got in too deep with the bucket. After about half an hour I noticed the yellow light on the left side of the dash was on. I poped the hood and put my hand on the motor and radiator. It was hot but not smoking hot. I even dared to twist of the radiator cap (not smart) and it spit a bit but didn't boil out. Plenty of fresh green fluid inside. Front of radiator was clean. The round air filter does need replacing but other than that I'm not sure what is going on. Wire to the senor seems ok. Any ideas?
/ That darn yellow light is on again!!! #2
Sensor could be going bad
/ That darn yellow light is on again!!! #3
You are over reacting, that is the Japanese "time for a cold one light!"
Could you be a bit more specific. If it were the heat sensor on my cars gasoline engin I would be very worried. Are you saying that it is different with diesels? I barely did any work with it. Is it typical for this motor to overheat that easily? I guess if it was serious they would have made it a red light and not a yellow one right?
/ That darn yellow light is on again!!! #5
When I first got my 1500D it was doing the same thing. The problem was the anti-freeze mix. If the engine is overheating but the radiator is not too hot, I would suspect that you have too much antifreeze to water in the mix. If the mix isn't right, it won't circulate so the hot water isn't getting to the radiator to cool. The engine will be too hot and the radiator will still be cool or just warm to the touch.
To test for that problem, drain all your coolant into containers and then refill with water only. Then go work the tractor. if it doesn't overheat with water, the problem was the mix ratio.
The thermal siphon cooling system in the 1500 will not work if you have more than 40% anti freeze to 60% water.
/ That darn yellow light is on again!!! #6
If I remember right I think He stated in his earlier posts that he was using a 50 50 mix. So if you are right that might be the problem.
I think we're on to something. I drained about two quarts out and added water, then went out and did pretty much the same job I had done when it previously overheated. It overheated again. I then took a towl and lifted the cap off. About a quart of water\coolant blew out. It couldn't have been that hot because I wasn't scalded. It was hot though. I then put in another quart of just water, went back out and worked her again. This time I couldn't get the light to go on. I'm thinking it was pure coolant. How much liquid does the cooling system hold, any idea? Guess I need to drain it copleatly and go to a 60/40 mix like you suggested.
/ That darn yellow light is on again!!! #9
I seem to remember that in past posts the experts have recomended less than 30/70 unless it gets very cold where you are. The correct mix does make a difference. You might want to read some of the old threads.
Chris
/ That darn yellow light is on again!!! #10
Guys,
Here's the deal with the antifreeze mix and older Yanmar, and other Japanese tractors (including some of the older US Kubotas). The older tractors (including Doug's 1500) don't have water pumps to circulate the coolant. The system relies on the change in density of coolant as it changes in temperature. Basically, the engine heats the coolant, and the coolant becomes less dense (or lighter), thereby tending to rise upward. The highest spot in the system should be the radiator upper tank - this is where the hot coolant tries to go. The warmer, lighter coolant moving toward the radiator is replaced from below with cooler coolant in the bottom tank of the radiator. This circulation is referred to as the "thermo-syphon" effect.
Water has a relatively high coefficient of thermal expansion - that is to say it gets quite a bit lighter as it heats. Anti-freeze does not get much lighter when it heats. The thermo-syphon cooling system relies on a very clean system and a large change in coolant density to work properly. So the more anti-freeze in the mixture, the less the coolant circulates. For these cooling systems, you should use as little antifreeze as is necessary to prevent freezing in the winter. This provides the most effective cooling in summer.
I know this is a long post, but hopefully it explains the concept for those with thermosyphon cooling systems.
/ That darn yellow light is on again!!! #11
Best explanation I ever heard......didn't realize the change in density of heated anti-freeze was that much less than that of heated water. I always thought the thicker liguid just didn't flow through the small passages as freely. Sure makes sense to me.
/ That darn yellow light is on again!!! #12
I recommend having the radiator rodded out for maximum cooling. It more than likely has scale buildup after 20 plus years. Then add 60/40 coolant mix.
Mike
/ That darn yellow light is on again!!! #13
I checked my YM169D operation manual and it said NOT to use more than 40% anti-freeze in the summer to avoid overheating.
Jim
/ That darn yellow light is on again!!! #14
Jim,
I was under the impression that the YM169D was very similar to the YM1401D which has a water pump. Does the YM169D have a water pump?
These restrictions on maximum anti-freeze apply only to the termosyphon (no water pump) engines.
/ That darn yellow light is on again!!! #15
Greg,
The YM169d and YM1401d are real close. In fact that is the manual I use for my 1401d's. The funny thing is that the service manual says a YM169 has a water pump, but the operation manual (under "service" page 63) says it does not (see attachment). The YM169d has a 3 cylinder engine just like the 1401d, so the service manual must be correct and the operations manual must be in error. The 40% mix is probably correct though.
Jim
/ That darn yellow light is on again!!! #16
I saw a post either here or the old Yahoo club,when talking about this same subject, that said there was an additive for racing engines and diesels that made the water carry more heat. If someone remembers what it was, it might be useful.
/ That darn yellow light is on again!!! #17
The capacity is just over a gallon. (4.2L = about 4 1/2 quarts)
Someone else mentioned a 30/70 mix and he is right. The old timers who helped me with this problem before told me a 30/70 mix.
The manual says not to exceed a 40/60 mix so anywhere between that is probably going to do the trick for you. Mine is actually a 33/66 mix since I just dumped a gal of anti-freeze into a 5 gal can, dumped 2 gal of water in with it and marked it for the tractor. Then I flushed the system with a radiator cleaner followed by a fresh water flush and filled it with the new mix.
My overheating problem disappeared.
/ That darn yellow light is on again!!! #18
One of the companies that makes this additive is Redline. It is called Watter Wetter. I used it on my CJ7 with a 454 in it. Worked very nice. I would recommend it for autos, but I will not mention tractors since I know basically nothing about them yet. I am doing a lot of reading trying to learn.
Just thought I would offer something on a subject I know.
Ken H.
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
Electric Golf Cart (A56859)
Electric Golf Cart...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2015 Ford F-150 Ext. Cab Pickup Truck (A59230)
2015 Ford F-150...
2018 Chevrolet Equinox AWD SUV (A59231)
2018 Chevrolet...
