Deere 4052R Service light on
/ Deere 4052R Service light on #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I posted this on the "Good Morning" thread and I'm posting the two posts on here...it might help you if you experience the same concern:
Last weekend I wrote about the tractor not starting on Saturday...just click...click. Sunday, one click, then the engine kicked over. My assumption was a bit of ice in the starter motor. Anyway, when it did start, a service light also illuminated. Called the dealer on Monday since I've only put 5-6 hours on it since it was delivered, after being serviced at the local dealer. Due to the holidays, they can't get anyone to the house to check it out. Although I'm not much of a mechanic (used to be OK, but my skills have not been kept up to date), I asked the service manager if he thought there was a way to reset the service light (owner's manual doesn't go in to this. Nothing in the service manual other then resetting using a Deere service laptop. However, from previous experiences, I have found that disconnecting the battery for a few minutes might do the trick. Deere service manager agreed but said if the service light does come back on to get the code that appears on the instrument cluster.
So, that's another project to do today since it will be relatively warm compared to the cold front coming in this weekend. I hope it works...
The service manager suggested that even if the light does re-illuminate, continue using the tractor. If there's a real problem, a red STOP light comes on. If that light comes on, park the tractor...
A bit of a bummer, but I won't get excited if this is a one time occurrence. Hopefully, this tractor isn't a lemon (what we referred to as a "Hanger Queen" in Naval Air). But it did have 321 hours on it since new (2015-2016) and I would think if this machine was a lemon, it'd show up long before 321 hours...
Follow up:
Good news!!
I didn't even have to disconnect the battery!
I started the tractor to move it a bit for access to the battery box (on the Deere 40xxR series tractors, the battery is located under the right side cab door). As usual on this cold weather, the fuel gage shows empty initially, and a warning on the instrument panel (not the service light). Fuel gage showed fuel (about 3/4th's full) a few seconds later, and no service light
So, used the front blade to scrape a bit more snow off the drive, parked the tractor and plugged it in(you may recall, I always plug the tractor in...just don't plug the extension cord in to the wall socket)
For you guys with the Deere 40xxR tractors, you may experience the same thing sometime
