Texas Spring/Summer Thread
/ Texas Spring/Summer Thread #5,571
Talking about snakes,, I would kill six to eight a year.. Copperhead mostly.. but about eight years ago a couple of caracara birds moved in.. then a couple of more,, then a couple of more.. Someone told me that they would kill snakes.. I said okay.. but I haven’t seen a snake in two years.. any kind.. but I think it is the fire ants.. now I need a bird that killes fire ants.. No Robbyr I can’t afford anteater.. don’t bring it up.. lol..but on second thought,, are they ag?,, how many pre acre? Lou
/ Texas Spring/Summer Thread #5,572
The best snake repellent I have found is powdered sulfer. The snake whatever it is will not cross it and it even works on mice. We buy it at Lowes or Home Depot or local hardware store
/ Texas Spring/Summer Thread #5,573
That must be what I have heard needs to be replaced after every rain.
hugs, Brandi
hugs, Brandi
Speaking of replacing after every rain. Some years ago I had a bit of a problem with cottontail rabbits grazing in my garden. Someone told me I could spread blood meal around the garden and the rabbits wouldn't cross it. It apparently worked, BUT I replaced it after every rain. And the prettiest grass on the 10 acres was that right around the garden.:laughing: And it required the most frequent mowing.
/ Texas Spring/Summer Thread #5,575
Yesterday Cher says "time to cut grass and clean up" ... fired up the JD rider and in a couple passes a squealing ... deck bearing bad. Fired up the push mower and in a couple passes I says Geez this blade needs sharpening ... Removing the blade I broke the bolt broke off!!! ... Cranked the weedeater and it wouldn't go full throttle ....
I stated the following .... Why in gods name am I stupid enough to have a large yard? I suggested we fence it off and put in goats !!! Cher replied something about my arce ... I don't think she approved of the goats!!
/ Texas Spring/Summer Thread #5,576
hugs, Brandi
Yes mamn you are correct but it does work I promise
/ Texas Spring/Summer Thread #5,577
BR,
I see you need to leave the wrenching alone;) and stay in the welding shop.:laughing:
hugs, Brandi
/ Texas Spring/Summer Thread #5,578
Lou maybe you should call the Brazoria County Appraisal District and find out if having anteaters would give you an ag exemption.:D. Now if only mesquite trees qualified for an exemption......
/ Texas Spring/Summer Thread #5,579
Tell them you're raising Bbq wood.
2025 Hydraulic Brush Cutter Mini Skid Steer Attachment (A59228)
2025 Hydraulic...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Equipment Trailer (A59230)
1986 Eager Beaver...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2025 Wolverine PFA-11-3300G 48in. Hydraulic Forks and Frame Skid Steer Attachment (A59228)
2025 Wolverine...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
