Testing the water... er Mud
/ Testing the water... er Mud #41
Here is a picture I have posted in the past; wish I had taken the ones up to the belly, but was kind of busy.
/ Testing the water... er Mud #42
Looks pretty steep to me even if it wasn't soft underneath. I would consider cutting the trees off and pulling them out with cable or chains with the tractor up on the top flat area. That would atleast get most of the problem slowed down till you can get a larger long reach excavator in there.
/ Testing the water... er Mud #43
Sorry to hear it didn't work as planned. But at least you know what you're up against now.
Is there any other approach closer to the actual trees that you could use a winch and whatever to get the trees out?
Could you get a wrecker or another tractor with a winch already on it to access the trees without sinking into the bog?
Could you cut up and burn the trees in place instead of trying to get them out?
MR. yote out.:)
Sunday I was trying to explain to my wife, who can out work me on her worst day, why we couldn't remove any more trees from the pond because I didn't have enough chains to reach. She looks at me and says "what about the strap in the bottom of that bucket in the back of the truck?" Oh you mean my 30' tow strap I had completely forgotten about? :eek:
Wouldn't try lifting much weight with a tow strap but it worked fine for dragging limbs closer to the edge to lift them up with up using just the chain. With this method I should have all the big limbs out before the pond refills this winter and dredging will have to wait until next year. Proving necessity continues to be the mother of invention.
/ Testing the water... er Mud #45
I'd have to side with Short Game on the cheap old fashioned methodology.
A walking bucket with a cable and winch would keep your tractor out of the slop. You're going to get covered with it walking the bucket back and forth though.
I've got a couple acres wet pasture I want to dig out; but the only way I can avoid big bucks to the EPA is to dig it by hand. Once the material is shoveled out, then I can use the bucket to move it to the garden.
/ Testing the water... er Mud #46
I had the feeling that you weren't even thinking about the Fetal position...At Least all the answers had you considering most of the angles. That is the Mob mentality at its best?If two heads are better than one then, 500 people read your problem, and many leave suggestions? great...
/ Testing the water... er Mud #47
500 people with shovels and buckets would be okay too. With not too much chain, they'd get those trees out of there too. Though, a few of them would insist their job was only to write the software.
/ Testing the water... er Mud #48
Look up Wikipedia 'corduroy roads'. I've come accross old corduroy roads laid down by loggers to traverse wet spots.
Or this
Part Three
/ Testing the water... er Mud #49
I got a BUNCH of old roofing tin that the cannery was going to bury as shipping is too much for recycling. I wanted it to sheet my root cellar and to build a bearproof smoker.
I used some of it to walk the tractor thru knee deep muck to where I wanted to do some work and it worked so well I am going to use it to make some roads across the muck, just cover it with gravel and have a road. I hope it will last 20 yrs or so before the metal is gone but I know it would last long enough to clean up a pond.
Rick
/ Testing the water... er Mud #50
When I tried just what you are suggesting, I found that the layer of silt I could stand on was about 2 feet above a water table. Picture a bowl 1/3 full of water and 2/3 full of sand with the top of the sand dried out and "solid", the bottom third sorta like quicksand.
My Dodge did get me out just fine though.
/ Testing the water... er Mud #51
With the dry weather the water level of my 1/2 acre pond is way down. I want to drive my FWD CUTS tractor into the pond basin for two reasons. First, to pull out several trees and branches that have fallen in over the 15 years of neglect before we owned the property and second, to use my box blade to remove a couple feet of accumulated silt. Although the pond bottom has been exposed for the last month and can be walked on, I can, with my considerable 225lbs, still push a shovel handle about 1-foot into the muck.
While I have never purposely needed to drive into this kind of situation, I assume I should drive in slowly and see how the front holds-up. I do have a loader that could be used to lift the front-end if I bury it but I have never actually used this technique. Worse case is I can hopefully pull the tractor out with my truck should I get brave (stupid) and get all 4 wheels spinning.
Finally the question; Is there a method to get a fair idea when your tractor will navigate mud without using the time proven, "Heh hold my beer and watch this," method. Time is of the essence as it usual gets pretty wet during the winter months. TIA
It's probably not dry anymore... but: 1) A dozer is the right tool. It will take forever with a utility tractor. You are really rebuilding your pond. In the old days the USDA would pay part of the cost but now with tree huggers everywhere, that may not be politically correct. 2) If you insist, start at the edge and use the loader to get out material until you are down to "dry" or at least firm surface. Make your self a road into it and don't ever put the tractor in the mud. 3) I've had a JD4700 in mud up to the frame in a swamp. Lifted the front end with the bucket, put wood underneath and fooled with it for an hour. Eventually inched it out by bucket strokes moving the tractor 6" per bucket stroke. I do not recommend it. 4) As a few hundred other guys said, forget the truck. If you get hung it will take a big machine to extract you. You are simply better off in the long run to hire a dozer and do it right.
/ Testing the water... er Mud #52
Have you considered steel cable? New is expensive, but you might find used cable to buy borrow or rent from a nearby construction co, junk yard or neighbor. If the trees are not that big the cable does not to be that big. Be careful if the chain or cable you are using snaps as anything that long can cause quite a whiplash effect if it breaks. GOOD LUCK!
/ Testing the water... er Mud #53
As for removing the muck you might look for an old horse drawn walk behind bucket scraper that you could pull with a chain/cable with the tractor on dry ground. They had two handles similar to a wheelborrow to control the cutting depth and dump. It would be a two person operation. They are probably impossible to find and have the capacity of a couple of large wheelborrows. My parents used one to dig the basement for our farm house in the 40's, and used a JD GP to pull it..........
/ Testing the water... er Mud #54
You mean like we discussed back on http://www.tractorbynet.com/forums/owning-operating/218985-testing-water-er-mud-3.html#post2506113 ?
/ Testing the water... er Mud #55
Exatly what I was talking about.....I got in on this thread late and did not read everything from the beginning. The picture shows the underside of the thing or as it would look after you let it dump. If anyone out there has on to sell I would be interested .............
/ Testing the water... er Mud #56
Don't go into the pond!!! :eek:
Be afraid. Be very afraid...:shocked:
I speak from personal experience.
See the pictures below.
/ Testing the water... er Mud #57
Wow! The ground around your tractor doesn't even look that bad (wet or swampy, that is)! I'd have fallen for it ... I mean into it ... too :eek: I Most of my acres is wetlands that look similar. Maybe I'll be posting similar pics someday. At least that big ol' pickup was able to help pull you out.
/ Testing the water... er Mud #58
Chain is cheaper than hiring someone. Buy more chain??
/ Testing the water... er Mud #60
It started out very overgrown. I was in the midst of brush hogging the brush. I had been over the same area several times when...... the bottom falls out from under me. :confused3:
I ended up hiring a guy with a BIG dozer and a track excavator that can practically reach across the pond. Now I'll have a pond 3 times the size and 20 feet deep in the middle. I could never have done what he did with my L3240. I tried, but it was beating up the tractor more than I care to. Money well spent. :thumbsup:
I'll put in a few pictures when he completes the job. He's still roughing the pond in. I'll do the landscaping after he's done. A man's gotta know his limits (and his tractors limits). :tractor:
Plenty more to do within the capacity of my tractor. :cool:
