Tell me what you see here?
Status
Not open for further replies.
/ Tell me what you see here? #101
"Recognition" based on what ??
Post a comment or contact the man in the video and offer to pay for a Swiss hammer test...!
Pine, I respect your experience. And I'll just assume you didn't see the rebar piling up when they were pouring? For me personally, that identitifies a poor quality pour.
/ Tell me what you see here? #102
Without seeing or being privy to the mix design analysis it is impossible to make even an educated guess as to the strength of the end product...
Depending on the said mix design the rebar could possibly have been entirely unneeded...
I'm not and never was defending the execution of placing the concrete...my point clearly was missed by many that made assumptions based solely on what the video displayed...
/ Tell me what you see here? #103
I understand. I never was commenting on the strength of the finished product.
The part you do not understand with all due respect is we all saw the same thing. We all, or I should say MOST of us can detect "VISUALLY" that the mix was too wet. I think that's not even debatable that the mix was too wet. Anyone that has ever poured a yard of concrete knows that the mix should look like.
OK don't take my word that the load was too thin even those it flowed out of the hose like water. Take the word of the people that actually make a concrete mix.
Project Instructions
When working with cement-based products, always wear eye protection and waterproof gloves.
Step 1
Empty the mix into a mortar tub or wheelbarrow and form a depression in the middle of the mix.
Step 2
Measure the recommended water amount (each 80-pound bag of concrete mix will require about 3 quarts of water).
Step 3
Pour approximately 2/3 of the water into the depression. If using liquid cement color, add to the mixing water.
Step 4
Work the mix with a hoe, gradually adding water, until the mix reaches a uniform, workable consistency.
Properly mixed concrete should look like thick oatmeal and should hold its shape when it is squeezed in a gloved hand.
NOTE: the more water that is added to the mix the weaker it becomes; adding one extra quart of water per 80 lb bag can reduce the strength of the concrete by up to 40%.
Mixing Concrete Hand Mixing | QUIKRETE: Cement and Concrete Products
There is now on earth what we all saw on the video..... looks like thick oatmeal and should hold its shape when it is squeezed in a gloved hand.
ALSO THIS:
When there is too much water in the concrete, there is greater shrinkage with the possibility for more cracks and reduced compressive strength. As a general rule, every additional inch of slump decreases strength by approximately 500 psi. So for example, if you ordered 5-inch slump concrete and received 7ス inches, a mix designed to be 4000 psi would end up being 2500 psi. This represents a serious loss in strength, especially if you were placing exterior concrete in a freeze/thaw climate where the standard requirement is 4000 psi for proper durability.
https://www.concreteconstruction.net/products/decorative-concrete-surfaces/when-concrete-is-too-wet_o
Finally, no one can determine what will ever drive on that concrete. The current owner may only place lawn mowers, but if he sells the place and the next owner wants to store heavy tractors in their then they will have a problem with the concrete being too weak.
/ Tell me what you see here? #105
Without knowing the complete mix formula it is IMPOSSIBLE to determine how much water would be too much...!
Here is a paste job that counters much of the incomplete data cited in the paste job of the post above...!
Anyone that has pumped concrete...especially vertically for long distances know how wet the mix has to be...!
...High slump or "flowing" concrete mixes are economical ready mix products that allow maximum flowability without sacrificing strength by adding water at the jobsite. These high slump, high strength properties are attained through the use of high range water reducing admixtures (superplasticizers). These mixes feature high slumps (8" - 11") without segregation or sacrificing strength. High slump concrete provides faster and easier placement.
Flowing Concrete (high slump) - Titan America
/ Tell me what you see here? #106
Yes, that is correct. It could be perfectly adequate concrete mix if the proper additives were used to make it flowable without sacrificing strength or having the aggregate sink to the bottom.
However, look at the video between 4:15 and 4:25. The mix looks thick. They're having trouble raking it from the pile. Now advance to 4:35. It's blasting out like water. My guess (and that's only a guess) is they realized they'd never be able to rake it into position with the labor they had, and then had the truck operator water it down. Only way to know would be to ask, but that's what we see. It might not be what it is, but that's what we see.
Then, watching the video, watching the prep of the site, never seeing anything compacted, watching the concrete blast the rebar off the ground all over the place, not seeing anyone correct any of that, nor mention of it, not seeing anyone attempting to lift the rebar (it would have just sunk again anyway in that thin mix), etc.... it leans to sub-par job to the average person.
/ Tell me what you see here? #107
When a driver shows up the ticket should say the mix design and how much water could be added. It is usually not very much, I have seen it say as little as 5 gallons for a full load. The only way to get it to flow better is with additives which can be kind of pricey.
/ Tell me what you see here? #108
That's a good catch MossRoad. When I watched it again, I noticed the truck is spinning in the "mixing" direction when they cut back to it at 4:30, not doubt to mix in the freshly added water. Then they blast out the thin mix seconds later.
/ Tell me what you see here? #109
Anyone trying to argue the points I have made are obviously completely missing them...!
Making assumptions and drawing conclusions from and playing video detective is just too funny...
/ Tell me what you see here? #110
I think pouring concrete is a terrible waste of money without rebar or at least mesh. Concrete only has limited tensile strength. Steel is like a gift from heaven for concrete. Especially considering it odd, that concrete and steel have the same thermal expansion coeficient.
I would have to disagree.
We have a lot of concrete at work that gets forklifts driven over it which weight 10-12k empty and 14-16k loaded (sometimes up to 16k when overloaded).
We just had a large (<26k sf) warehouse put up with floors designed for those loads.
The ONLY metal in the floor is the dowels between the sections of the pour and between the walls and the floor.
None of it has mesh or rebar in it. Fiber and plasticizer, yes but rebar or mesh, no.
Now the walls and the footer do have rebar in them, but not the floor.
Aaron Z
/ Tell me what you see here? #111
Aaron Z
So your concrete has fiber in it, right? And you dont have breaking or cracking issues.
Some people use rebar. Some use wire mesh, some use fiber. Some use combinations. I think the point he was making is that he wont pour a slab without rebar or some type of reinforcement. Neither would I.
In the video pour, we dont know what the underlying ground conditions were. For all we know, several trees could have been taken down to make room for the garage. IF that is the case, then rebar would be an absolute requirement for me over ground compacted in lifts.
We dont know the history and the background of the ground preparation.
I watched a garage project where a smaller older garage was razed and a larger one was built over the footprint. Rebar was not used and the floor cracked later.
As I and many others have said, its not a panacea, but an insurance policy to prevent cracks from becoming sinking areas of uneven concrete.
If given the choice, I bet most customers would opt for properly installed rebar than nothing. I have lived by that technique and managed to live a peaceful, prosperous life with few call backs and continuous construction work load.
/ Tell me what you see here? #112
LoL...Are you now or have you ever been a licensed general or masonry contractor, architect, engineer? were you ever employed by said professionals as a career ?...if not your opinions are those of an amateur...there are lots of amateur contractors out there...
BTW FWIW... the biggest job I ever had responsibility for was several portions of the (new) 7 mile bridge in the FL keys...as a contractor for Misener Marine...
Oh I almost forgot...I never did any work for the DoD (Pentagon etc.) but I did turn down a chance to work for the State dept....the job was going to Russia and working on the second US embassy building...after the original new one was found to be loaded with bugs and eavesdropping equipment...that was for the Brown company...
I dont need a college degree (although I have one) to know whats right and wrong. I was taught by an accomplished mason from the Isiah Williamson School of Trades. One of the best trade schools in the country. That man passed away a few years ago. He was my father and I have the utmost respect for him. He was an excellent mason. Respected and referred for 50 years in my community. I have continued that tradition.
Your insinuations are getting a little personal and close to home, which is amusing considering you were the one whining about unfair treatment by our moderators in another thread you started.
With all due respect, try a little humility, stop calling other TBN members “amateurs” because they dont have a degree from Harvard school of engineering and show some respect and youll get respect back.
I have taken many “architects” plans and reworked them using value based engineering and gotten a lot of respect back from them and saved my customers many thousands of dollars.
Residential concrete work differs from all the bridges you watched being built from an air conditioned office trailer. Just because you were on a supervisory crew for a concrete bridge, doesn’t make you an expert in smaller projects. I wouldn’t want a contractor that builds sky scrapers build my garage and vice versa.
/ Tell me what you see here? #113
True, but making the assumption that all is well is also in itself, an assumption or conclusion. I think we can all see the rebar was installed and treated improperly during the pour and other precautions were missing. Therefore most of us “Amateurs” are also betting the concrete mix was runny/watered down and not runny from additives due to the aforementioned improper rebar installation.
/ Tell me what you see here? #114
I think we can all agree that by the appearance of the pour in the video, that slab was not poured in a manner conducive to getting the most strength possible out of the slab.
It may be enough to do what the homeowner was trying to do, but it could have been significantly stronger had it been prepared and poured differently.
The point that I was trying to make was that a blanket statement of "it's a waste of money to pour a concrete slab without rebar in it" is incorrect given the concrete that is currently available.
Aaron Z
/ Tell me what you see here? #115
I worked for a company that had a parking pad poured for a Boeing 707 aircraft - no rebar was used, only dowels to tie the separately poured slabs together. No cracks that I noticed in the 20 years I worked for them. BUT, I know that there was a lot of engineering that went into the slabs. My neighbor worked for the concrete supplier so I got to see both sides of the job.
/ Tell me what you see here? #116
...I have taken many architects plans and reworked them...
You mean like the guys in the video did with the rebar ?? :laughing:
/ Tell me what you see here? #117
Several of you guys need to put in a request to the people in the video. Need the paper work for the soil testing before the job started. The paper work on recommended soil additives. Need the paper work on the compaction testing. Need the paper work on the slab prep from the engineer. Need the info on the concrete mix recipe from that engineer. Finally need the paper work from the cylinder tests for each truck load from the concrete pour. Contraction and expansion joint plans. Paper work on recommended curing and sealer agents after the pour.
Probably left out some things but it should be a start.
/ Tell me what you see here? #118
LoL...they relied on "value based engineering" :laughing:
BTW I already suggested a simple Swiss hammer test...it would be telling since it's after the fact...!
Everyone can see it pours out like water which would bring a COLLAPSED SLUMP.
/ Tell me what you see here? #120
LoL...I'm more than familiar with ASTM C143 / C143M methods...
without knowing the mix formula the slump means ZERO...what is it you don't understand about an 8"-11" slump being copacetic ??
Status
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2017 SANY SY365C LC EXCAVATOR (A60429)
2017 SANY SY365C...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
2018 VOLVO EC350EL EXCAVATOR (A60429)
2018 VOLVO EC350EL...
2006 JLG E400AJPN ELECTRIC BOOM LIFT (A60429)
2006 JLG E400AJPN...
