Tell me what you see here?
Status
Not open for further replies.
/ Tell me what you see here? #51
No rat wall either. That don't fly around here. Code is at least 4 feet around the perimeter including any door openings. When I poured my shop floor for the new machine shop, I used cattle panels instead of rebar and stood the PEX off the panels with plastic standoff's.
No 4" or 6" either, 10" thick, 4 bag mix. I have heavy machine tools on it. In the winter, I keep the floor at 70 degrees. Floor heat is wonderful.
Yep. I've only had it one Winter in our house. Two Winters in the shop . I love it. :)
/ Tell me what you see here? #52
Rebar is not needed for most slabs, the vast majority of pavement I have worked on is not reinforced. They did not show compactor, but they have used one. Based on dust comments the wet concrete appears to be from excess water.
What is a rat wall?
/ Tell me what you see here? #53
What is a rat wall?
Its a wall underground to keep rodents from burrowing under barn walls
The wet concrete could show up as shrinkage cracks later
/ Tell me what you see here? #54
I have never heard the thickened edge of slab called a rat wall before
/ Tell me what you see here? #55
I'm curious, if you have no reinforcement in the concrete and are putting up an unheated structure in cold climates; aren't you depending on good compaction, equal across the entire slab, and hoping that it will stay together when it cracks?
/ Tell me what you see here? #56
I was under the impression that the purpose of rebar in residential construction was to hold the edges of concrete together when it cracks. Am I mistaken?
I'm aware that some concrete construction does not use rebar - i've seen parking pads for commercial jet aircraft without it.
/ Tell me what you see here? #57
It's obvious many are not discerning the difference between a structural and nonstructural slab...
In nonstructural slab pours the reinforcement usually either wire mesh and or fibers is there to prevent cracks from widening...
on simple monolithic slabs where a footer along the perimeter is poured at the same time as the slab (for load bearing purposes) rebar is usually placed in the footing...
/ Tell me what you see here? #58
Not only is the rebar to help prevent the cracks from widening, in frost areas it helps keep the cracked sections from lifting at different levels.
/ Tell me what you see here? #59
A rat wall is a trench dug around the perimeter of a structure usually to the depth of the frost line (here 4 feet) and it's required by building code. What we call it here.
/ Tell me what you see here? #60
I think pouring concrete is a terrible waste of money without rebar or at least mesh. Concrete only has limited tensile strength. Steel is like a gift from heaven for concrete. Especially considering it odd, that concrete and steel have the same thermal expansion coeficient.
Status
Ford 8210 (A60462)
Ford 8210 (A60462)
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
2017 INTERNATIONAL 4300 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2017 INTERNATIONAL...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
Woods DS8.50 (A60462)
