Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 21,732
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
I realize the question posed is "what do you see here"...but what I see "here"...is a bunch of amateur armchair engineers...!
There is really no information on the actual mix of the concrete for all we know it could have been a high PSI mix to allow for a wet, easy to place pour...it could also have had fiber along with a rich Portland content which greatly increases the tinsel strength of the slab eliminating the need for wire etc...
As for the rebar...for the most part unless there is a deeper "stiffener" required for specific load bearing purposes etc. most slabs do not even require a rebar grid (wire mesh and or fiber is all that is required to obtain the required strength)...there are millions of basic floor slabs designed by engineers and architects where no rebar was/is required..in a majority of cases rebar for this type of application is merely overkill...
I'm not saying the above is the case it does look like a lousy, amateur job but you can't always base things on the way they appear...
Control joints are often sawed shortly after the pour is made...
I always base things on the way they appear. In fact, I always say I see better than I hear
Also, Im not an armchair engineer. Ive done hundreds of pours for house basements, garage floors, patios, and covered porches. Ive dug and poured miles of footings dating back to when I was 14-15 years old working for m dad.
I know bad construction techniques when I see them. If rebar wasnt necessary because high/early mix was used or fiber was added, then why even use rebar? Also the rebar wasnt drilled into anything for edge support. It was just laid on the floor with no chairs.
That wasnt a total disaster, but it was below average.
