TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-(
   / TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-( #31
Disconnect the existing wire to the fuel solenoid, at the solenoid. Run a new wire from the run position of the key switch to the fuel solenoid.
Run another wire from the start position of the key switch to the starter solenoid.
Should start and run and also will shutdown when you turn off the switch.
Will also need to connect a glow plug timer from the glow plug key switch position to the glow plugs.
Glow plugs should run about ten seconds while holding the key switch to the heat position and then stop.
Keep in mind that doing this will bypass all of the safety functions
   / TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-( #32
Don't forget to unplug the safety controller connector
New Holland TC21D (A53317)
New Holland TC21D...
2012 Ford Escape XLT SUV (A55853)
2012 Ford Escape...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
