TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-(
   / TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-( #31
Disconnect the existing wire to the fuel solenoid, at the solenoid. Run a new wire from the run position of the key switch to the fuel solenoid.
Run another wire from the start position of the key switch to the starter solenoid.
Should start and run and also will shutdown when you turn off the switch.
Will also need to connect a glow plug timer from the glow plug key switch position to the glow plugs.
Glow plugs should run about ten seconds while holding the key switch to the heat position and then stop.
Keep in mind that doing this will bypass all of the safety functions
   / TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-( #32
Don't forget to unplug the safety controller connector
24008 (A53422)
24008 (A53422)
UNUSED FUTURE SF60 HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2012 Ford F-350 Knapheide Service Truck (A55852)
2012 Ford F-350...
