TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-(
   / TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-( #31
Disconnect the existing wire to the fuel solenoid, at the solenoid. Run a new wire from the run position of the key switch to the fuel solenoid.
Run another wire from the start position of the key switch to the starter solenoid.
Should start and run and also will shutdown when you turn off the switch.
Will also need to connect a glow plug timer from the glow plug key switch position to the glow plugs.
Glow plugs should run about ten seconds while holding the key switch to the heat position and then stop.
Keep in mind that doing this will bypass all of the safety functions
   / TC30 Won't turn over - Do I need a new Safety Controller? Big Bucks :-( #32
Don't forget to unplug the safety controller connector
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2024 CFG Industrial KRW232 Mini Wheel Loader Skid Steer (A55851)
2024 CFG...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
2002 Bobcat 763 Compact Skid Steer (A57024)
2002 Bobcat 763...
