Tale of Two Inteks
/ Tale of Two Inteks #1
alexsbuddy
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
In the span of one week, I have had to replace the head gaskets on both of my lawn tractors. One is a Troy-Bilt and the other is a Craftsman. Both have B&S single piston OHV Intek engines; TB has a 17.5hp and the Craftsman has a 20.0hp. The repair is fairly straightforward (there are also some good You Tube videos).
In both cases, the engine was running just fine and then suddenly began exhausting a tremendous amount of white smoke. When it happened with the first tractor, I thought it was a catastrophic failure but then learned of the problem with the head gasket on the Intek.
The Intek is a simple engine to work on and, albeit the head gasket issue, is fairly rugged and reliable. My point is.....if this happens to you, don't run out and buy a new tractor. The repair/fix is easy and the cost (less than $40 for all gaskets, oil, and oil filter) is a whole lot less than a new lawn tractor.
/ Tale of Two Inteks #2
Well I would not go out and buy a lottery ticket right now with your luck. Odd that two would happen so close together, but also nice to have an engine where you can easily fix it.
One is a 2007 and the other is a 2009, but I am guessing they have nearly the same # of hours on them. Will check tomorrow...put HR meters on them when I bought them.
3pt Counter Weight (A64127)
3pt Counter Weight...
Chandler PT Stainless Steel Spreader (A64126)
Chandler PT...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
