Taking logs to the mill
/ Taking logs to the mill #1
Billrog
Armstrong, British Columbia
Kioti 2610, 580 SuperM Case Backhoe
/ Taking logs to the mill #2
Nice...very nice. (y)
/ Taking logs to the mill #5
Cedar 30" at the butt. Never measured the length but it was a tall tree. Got enough lumber out of it to fill an order of 6x6,2x6, 4x4's & 1x6.
Nice. Hard to see the species from the photo. Now I see you’re from BC.
/ Taking logs to the mill #6
Nice cedar. Not only does it have some size, but you somehow grow it straight up there!
/ Taking logs to the mill #7
😲 Lucky to find 16-18 butts around here. Any that you do find usually has barbed wire buried in it. I would much prefer to build my outdoor stuff with cedar instead of this “new” pressure treated stuff.
I unhook the trailer and load with the tractor. I had a regular set of forks yrs. ago but soon found that's a good way to take front seals and bearings out on small tractors by over loading. So I made of 16" detachable forks. You can see in the pick I'm carrying a log in front of my bucket as well.
/ Taking logs to the mill #10
Yes I see what you mean - for the same reason I ended up dragging whole bunch of logs behind my tractor last fall by using a short logging chain.
These logs were not nearly as big as in your photo, but some were very long & heavy nevertheless.
Hybrid Poplars, loaded with water:
It was an experiment, but I will never again plant these species!
No poplar on my property but some large cottonwood they are heavy and full of water as well.
/ Taking logs to the mill #19
I have a Fransgard winch ( borrowed picture ) I have it on the back of my tractor 90% of the time , it is very useful not for only skidding logs but getting vehicles out of a ditch etc or even getting the tractor itself unstuck.
Plus it is a great counter weight with my 4 in 1 bucket on my tractor.
2025 Bobcat T650 (A64126)
2025 Bobcat T650...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
Bush Hog 13414 (A64126)
Bush Hog 13414...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
