Taking logs to the mill
/ Taking logs to the mill #1
Billrog
Armstrong, British Columbia
Kioti 2610, 580 SuperM Case Backhoe
/ Taking logs to the mill #2
Nice...very nice. (y)
/ Taking logs to the mill #5
Cedar 30" at the butt. Never measured the length but it was a tall tree. Got enough lumber out of it to fill an order of 6x6,2x6, 4x4's & 1x6.
Nice. Hard to see the species from the photo. Now I see you’re from BC.
/ Taking logs to the mill #6
Nice cedar. Not only does it have some size, but you somehow grow it straight up there!
/ Taking logs to the mill #7
😲 Lucky to find 16-18 butts around here. Any that you do find usually has barbed wire buried in it. I would much prefer to build my outdoor stuff with cedar instead of this “new” pressure treated stuff.
I unhook the trailer and load with the tractor. I had a regular set of forks yrs. ago but soon found that's a good way to take front seals and bearings out on small tractors by over loading. So I made of 16" detachable forks. You can see in the pick I'm carrying a log in front of my bucket as well.
/ Taking logs to the mill #10
Yes I see what you mean - for the same reason I ended up dragging whole bunch of logs behind my tractor last fall by using a short logging chain.
These logs were not nearly as big as in your photo, but some were very long & heavy nevertheless.
Hybrid Poplars, loaded with water:
It was an experiment, but I will never again plant these species!
No poplar on my property but some large cottonwood they are heavy and full of water as well.
/ Taking logs to the mill #19
I have a Fransgard winch ( borrowed picture ) I have it on the back of my tractor 90% of the time , it is very useful not for only skidding logs but getting vehicles out of a ditch etc or even getting the tractor itself unstuck.
Plus it is a great counter weight with my 4 in 1 bucket on my tractor.
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
CATERPILLAR CS44B...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
