T474 Weight
/ T474 Weight #11
I have the same truck. The brake controller should be able to stop it. I have to drive through the mountains so my truck isn't going to be enough.
Old topic but relevant. Have you moved your 474 with your F150 5.0l a lot? Just wondering how it did and what trailer you have.
/ T474 Weight
No, my FIL used his f250 and a 10k trailer. My f150 would have **** a brick going up the hills
/ T474 Weight #13
My T574 is a bit bigger, but I did the math and decided I didn't want to buy a bigger truck just for the (hopefully) rare situations where I wanted to take my tractor off property. I have a stout trailer, but I made sure it wouldn't handle my tractor. This way I will not be tempted to 'try'.
/ T474 Weight #14
I brought my new T474 home on a 7K-LB equipment trailer shown in my avatar photo this past Friday (12/22) when leaving the dealership about 60 miles away. My Tow Vehicle (TV) is a '21 RAM 3500 Big Horn CC 4WD LB DRW w/CTD HD Torque. Truck had no problem, and the electric brakes on both axles of the trailer worked flawlessly.
Trailer had me a little worried as my calculated T474 HST weight was 5146-LBS per the manual with the loader and loaded rear wheels (+838-lbs). I was probably over the GVWR by a couple hundred pounds as I wasn't aware the rear tires were loaded until I questioned it at the dealership. Had I had that info before I left the house, I would have went to a 'stouter trailer'.
I won't tow the T474 again unless it's on a 7'x20-24' Equipment Trailer w/5200-LB axles (MINIMUM) or better yet dual 7K-LB axles with electric brakes on BOTH AXLES! YMMV...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
