Buying Advice T4.100F Vineyard Orchard Tractor
/ T4.100F Vineyard Orchard Tractor #1
robertgalka
Winnipeg Manitoba
Kubota L4060
Does anyone here use one of these as a regular farm/yard tractor? I wan't to upgrade my current John Deere, but everything with 60+ HP is too tall to fit in my buildings. I like the fact that they are narrow and not too tall. I would just use it for blowing snow, tilling and cultivating. I would like to put a loader on it also, if possible. Probably not the best loader tractor though.
There isn't any of these for sale local to me, so I would have to buy one sight unseen and get it shipped. I think they must be reliable, because you see some advertised with over 10,000 hours on them. I would like to buy one with under 2,000 hours. I probably only use a tractor 50 hours a year, so one should last me forever.
/ T4.100F Vineyard Orchard Tractor #2
Have a quality welding shop shorten the ROPS of your next (standard) tractor.
I had 4" removed from the ROPS of my L3560 before it could pass under my 84" garage header with the ROPS folded.
I need a cab model. I did shorten the ROPS on a John Deere I bought 20 years ago. I then bought a cab model and had to replace overhead doors on two of my buildings. My building that I usually store the tractor in has about a 93" high door. Most over 50hp tractors are a little taller than that.
The seller measured his T4.100F and said it is 96" tall. He originally said it was 89".
I'm not sure if I could go back to an open station tractor for the winter?
/ T4.100F Vineyard Orchard Tractor #4
For what it’s worth my 2013 T4.105F is 89” tall , top of cab
The one that I was looking at was a 2019, they look similar to a 2013 to me. I'm sure they come with different tire options, but you would need a drastic tire change to alter the height by 7". I know they have a really complicated filtration system for the cab, maybe
that makes the newer tractor higher?
/ T4.100F Vineyard Orchard Tractor #6
That roof looks more like my 06 tn95f which may be slightly taller than the 13 t105f . I can measure height tomorrow, both have about tallest tires available for them, I think 28” rims. Both have been good tractors, supersteer axle makes them super tight turning 👍
/ T4.100F Vineyard Orchard Tractor #8
You had me curious so I ran back over to measure. Sure enough the 06 is almost 96”. Evidently they made them shorter for few years like my 2013 then went back to taller 🤔 . Both mine have 420/70/28” tires
Thanks, the fruit cab is also an option. I'm not sure if they have heat though?
I ended up buying a Kubota L4060 with a 74" front mount snowblower, and a loader. It does everything that I need it to do. I didn't blow snow with it yet, however since the snowblower is made for the tractor, I'm assuming it will work good.
The orchard tractors have their purpose, but I think I'm better off buying what I did.
How did you go, Robert?
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
2014 Venture (A59231)
Mower King Brush Cutter (A53317)
Mower King Brush...
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59905)
2016 KENWORTH T680...
2016 JCB 507-42 TELESCOPIC FORKLIFT (A60429)
2016 JCB 507-42...
