System Bleeding?
/ System Bleeding? #1
prof fate
Platinum Member
beaver pa
kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
My Hydraulic fluid got low (not a lot..still on the dipstick) and the bucket tilt cylinders got wonky, so I filled it and it's 95% good...the bucket tilt seem a tad off though, like they need bled.
I've put the bucket up, and down, and worked it all around (not quite the hokey pokey though).
When I set the bucket down it seems to be less than solid. If I move the lever it's got all it's power, but it's like it's got air in the system and moves when it used to sit/hit solid without me having to move the lever.
Kioti CK3510HST with 200 hours on it.
/ System Bleeding? #2
Cycling boom/bucket several times should eliminate any air in FEL hyd circuits UNLESS air is being sucked into tractor hyd circuit which would need to be corrected.
/ System Bleeding?
that was my understanding. i have one line that weeps some..i'll see if I can tighten it or what's leaking. it's under warranty but i hate to burn up my free service call on a weepy hose.
/ System Bleeding? #4
If fluid can get out, air can get in.
2011 FORD F-150 (A65643)
2011 FORD F-150...
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
John Deere 2680H (A64126)
John Deere 2680H...
