System Bleeding?
/ System Bleeding? #1
prof fate
Platinum Member
beaver pa
kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
My Hydraulic fluid got low (not a lot..still on the dipstick) and the bucket tilt cylinders got wonky, so I filled it and it's 95% good...the bucket tilt seem a tad off though, like they need bled.
I've put the bucket up, and down, and worked it all around (not quite the hokey pokey though).
When I set the bucket down it seems to be less than solid. If I move the lever it's got all it's power, but it's like it's got air in the system and moves when it used to sit/hit solid without me having to move the lever.
Kioti CK3510HST with 200 hours on it.
/ System Bleeding? #2
Cycling boom/bucket several times should eliminate any air in FEL hyd circuits UNLESS air is being sucked into tractor hyd circuit which would need to be corrected.
/ System Bleeding?
that was my understanding. i have one line that weeps some..i'll see if I can tighten it or what's leaking. it's under warranty but i hate to burn up my free service call on a weepy hose.
/ System Bleeding? #4
If fluid can get out, air can get in.
Lifts (A61567)
Lifts (A61567)
2008 Ford F250XL, Crew Cab (A62679)
2008 Ford F250XL...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2005 John Deere 7420 (A60462)
2005 John Deere...
265/75R16 New Tire (A62613)
265/75R16 New Tire...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
