Snow Equipment Buying/Pricing Sub cut front snow blade quote
/ Sub cut front snow blade quote #1
75H2
Johnstown, Pa
MF GC 2300
I'm pricing a front blade for my Massey SCUT. I already have the loader valve, but need the blade and the QA mount. Ist number came back just under $1,900 if I do the installation. Is that number in the ballpark?
/ Sub cut front snow blade quote #2
It would hepl to know what tractor it's for.
/ Sub cut front snow blade quote #3
There's a video on u-tube where someone adapted a John Deere 54 blade to the front of a GC2300. If this is the tractor you have you may want to look at that.
Good point, it's a GC2300 The price was for the 60 inch blade with the optional side to side hydraulic control.
/ Sub cut front snow blade quote #6
Sounds like it's about in line at $1900.
/ Sub cut front snow blade quote #7
That is a good price. I was quoted that for just the mount/sub frame for ours, so yeah, that is good IMHO.
/ Sub cut front snow blade quote #8
Yeah, that is pretty close what I paid for mine, 60" top of line, with QC. You can keep shopping around.
/ Sub cut front snow blade quote #9
Boy Fred
They make you guys tough up there in Michigan plowing snow in sandals and shorts. Would not want to run into you in a dark alley.:D
Chris
/ Sub cut front snow blade quote #10
I got a rough quote of $1800 for a quick attach frame mount 4 way powered blade (Hydro Up/Down, L/R) for our BX2660 from the local Kubota Dealer this week.
Aaron Z
/ Sub cut front snow blade quote #11
Boy Fred
Chris
Chris, that was hilarious!!!! That was delivery day in July, of course. Actually, we had snow in the air yesterday. Brief spit, only lasted a few minutes, but you get the idea. I'll be posting some photos this winter from here at 45th parallel. Doubt you'll see any sandals and shorts.:D:D:D
We're tough, but not that tough.
/ Sub cut front snow blade quote #12
I paid $1200 for a 54" all hydraulic to fit my John Deere 2210.
/ Sub cut front snow blade quote #13
I have about $1,250 into a 54" Kubota front blade that I'm making into a 4-way hydraulic plow. The standard 54" is manual angle. Blade and qick hitch with hydraulic up/down was about $985. If I could have done the welding myself, I could have saved about $120. The Kubota 60" 4-way hydraulic plow retails for almost $2,000.
/ Sub cut front snow blade quote #14
Actually the 60" front hydraulic angle front blade retails for $1392.00. The quick hitch which you will need for either the 54', or the 60" retails for $586.00 per the Kubota site. The 54" blade itself retails for $421.00. Not trying to argue with anyone, just showing where the dollars go for the different options.
/ Sub cut front snow blade quote #15
Chuck, yes, I did not specifically mention the quick hitch was part of the $2,000 +/- quote for the 60" but of course it's needed to actually mount it. Your prices confirm what I was quoted, so for a lot less, I got the 54" with 4-way hydraulics. Still leaves one to question why Deere's 54" with OEM 4-way hydraulics is around $1,200 and Kubota's 60", albeit heavier and larger, is $800 more. I think they should offer the 54" with the option for 4-way hydraulics, like Deere does.
/ Sub cut front snow blade quote #16
OK, just checked and the Deere 54" front blade with hydraulic lift and angle for a JD2305 retails for $1,298. Same set up for a 2320, 2520, or 2720 is $1,347.
/ Sub cut front snow blade quote #17
My 60 in Hyd lift and angle sold for $1900 But I got a deal .
$1500 installed with all the parts/pieces and ready to go.
