Stupid Tractor Tricks
/ Stupid Tractor Tricks #41
I've been debating trailers and ramps myself lately. Ramps with knees will only help if they are hinged, not merely slide ons. I originally thought I could get the stowable ramps and weld on the knees, but as soon as the tractor goes from the ramp to the trailer tail... same problem. I'm thinking I'll stick with stowable ramps and use wood blocks under the trailer tail.
Rob
/ Stupid Tractor Tricks #42
I use a jack stand on my trailer. right in the center between the ramps. Stops the back of the truck from coming up. Just remember to leave some space so you can get it out once there is a load on the trailer.
Von
/ Stupid Tractor Tricks #43
OK I'll show my ignorance. What are ramps with knees and "scotched on"
I assume they are ramps with support at the high end, sort of a triangle. I'm shoppping for a trailer and the dealers try to talk me out of the trailers with the hinged ramps that have this support at the end of the trailer when the ramps are down, then want to charge me more foe these post that drop down to support the trailer end.
I got so confused about several options that I just decided to rent a trailer a few times and see what I really need.
/ Stupid Tractor Tricks #44
Not too ignorant, mdbarb./w3tcompact/icons/wink.gif I think you've got it pretty well figured out./w3tcompact/icons/smile.gif
Bird
/ Stupid Tractor Tricks #45
RobS,
Have you consider a tilt trailer bed with a duck tail instead.
Duck tail what we call a trailer up here that has about 22 degree angle which pitches down at the end of the trailer.
I believe Breaver Trailers have something in this line.
Thomas..NH /w3tcompact/icons/wink.gif
/ Stupid Tractor Tricks #46
Thomas, I've looked at all sorts of trailers but budget constraints will probably keep me in a fairly basic 18' beavertail (same as ducktail?) car hauler. I've seen some pretty slick tilt-beds, but they are pretty pricey.
Rob
/ Stupid Tractor Tricks #47
Here are the promised, better late than never, pictures of the Stump of Gibralter. I also have pictures of one of the 36+ inch oak stumps as well as a print of the pile of timber I moved with the 4n1 bucket, if anyone is interested.
Enjoy.
Dan
Dan -
That's one stubborn-looking puppy, alright. /w3tcompact/icons/crazy.gif
For those of you who might have trouble viewing TIFF files, try the attached JPEG version.
/ Stupid Tractor Tricks #49
Harv,
Thanks for the conversion to jpg. I could have sworn our scanner did jpg but it does not. I have not had any time to find a conversion program but eventually I'll get one. I posted the pics yesterday but then noticed someone had changed the defaults on the scanner so I deleted the posts. Big mess. :cool:
If the weather holds I'm going to have a stump digging weekend. Mainly little bitty things, 4-8 inches but a few 30-36 inch oak Big Boys. I'll be applying my Stump of Gibralter techniques to see if it goes faster/easier.
Thanks Again,
Dan
/ Stupid Tractor Tricks #50
Dan,
By the looks of that root system you were a tad busy for a while,but at least you had good open space to work.
May the other stumps remove easier.
/ Stupid Tractor Tricks #51
Re: Stupid Tractor Tricks-flipped it
Here is a bad day at the office. Thank goodness it wasn't me!!!
/ Stupid Tractor Tricks #52
/w3tcompact/icons/shocked.gif
Hope the operator okay.
Would that be a Cat dozer by the way.
/ Stupid Tractor Tricks #53
That was a bad day/w3tcompact/icons/frown.gif
Do you know what happened? Looks like he was skiding, looking back, and drove into a big hole.
/ Stupid Tractor Tricks #54
I'll bet he sure was proud of that roll cage, especially if he had a seat belt on.
Bird
/ Stupid Tractor Tricks #55
Bird,
I can't recall ever running one that had seat belts! All I've run have had the roll cage (except the old Cletrac), but no belts. Of course, the last one I was ever on, was a JD12 that I worked for several months.
/ Stupid Tractor Tricks #56
Scruffy, I've only operated one, and only for a very brief time, can't remember for sure but think it was a Case 580, and it didn't have a seat belt. Maybe none of them do; I just assumed the newer ones would have.
Bird
/ Stupid Tractor Tricks #57
Bird and Scruffy, The last company I worked for had a newer D9 that had seat belts. MSHA requires seat belts on all machinery operated in a mine setting, and can levy a hefty fine if they are not being used. I guess they could have been added on, but my guess is they come equiped.
ErnieB
"We were surrounded by some gross, proud, and victorious men. Anyone who knows the character of the North Americans can judge what our situation must have been."
Jose Juan Sanchez Navarro
/ Stupid Tractor Tricks #58
Gordon, what size or model was it....?
/ Stupid Tractor Tricks #60
The S.O.G was somewhat in the open, well, after I "dozed" the slash out of the way it was open. :cool: I went after a bunch of stumps this past weekend and pulled 40-50. The average size was in the 6 inch range. But I did get out a 36 inch oak stump. 2.5 hours of work but I think I can get it under 1 hour as I figure out the root systems.
I went after the oak like it was the pine which I think was overkill. If the weather permits I'm going after the remaining 4 oaks that need to be removed next weekend. I'm thinking I can get them out by digging under them on one side and then moving the tractor forward a few feet to cut the remaing roots. Hopefully under an hour. :cool:
When I have a bit more time into this and really have the technique down I'll post my How To Remove Stumps in the Rural section.
I pulled quite a few 1-6 inch pine stumps with the 4n1 bucket as well. It was like pulling teeth! :cool: Thankfully not mine! :cool:
The power company is putting underground lines into my neighbor's house site this week. I had left a 60 foot section of pine saplings on the side of the road as a screen. But they have to come out for the power company. When I did this by hand I was lucky to do 150 feet of road per VERY hard and HOT work day. But also leaving the cutoff stumps in the road. With the tractor and the 4n1 FEL I did 60 feet in an hour. That was everything piled up and most stumps out of the ground. AND I did not work up a sweat! :cool: Course the tractor did not care either. :cool: Sure wish I had the 4700 last spring! :cool:
Later...
Dan D'Stump'n Man!
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
2018 Bobcat T590 (A64126)
2018 Bobcat T590...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
TR 23 Trancher (A64127)
TR 23 Trancher...
