Stupid Things I Have Done
   / Stupid Things I Have Done #381
... but sometimes I think that the Amish have the right idea; it would be easier to buy a horse. :D
You would be wrong... Every horse is different, in looks, size, age, temperament, and most importantly training...
Except for James Bond's car... none has ever launched a person into the air. I personally have, multiple times, witnessed and experienced a horse doing this....o_O
   / Stupid Things I Have Done #382
You ever tried to change the fluids on a horse?
Bruce
No, but I learned not to ask that age old question; "If Jack helped you off a horse..."
The last time that I did, the guy said "Done it." His wife was big into barrel racing.
   / Stupid Things I Have Done #383
Luckily I only lost about a quart of fluid when I pulled the plug and put the gasket back on, but sometimes I think that the Amish have the right idea; it would be easier to buy a horse. :D
Yeah, but if you ever owned horses, you'd know they come with their set of challenges too.
   / Stupid Things I Have Done #384
This one my son did when he was a teenager. We bought him an older Toyota Cellica as a first car. It was high mileage and used oil so he had to check oil often. He came home one day and said he had oil all over his hood and it had been that way a couple day. Of course there was lecturing involved about driving it so long and not checking blah blah.
I went out popped the hood and there was the oil cap laying in a crevice on the engine. No oil on the dipstick. Car was making a lot of engine noise after. I decided to have a mechanic look at so about a week later we took it to a mechanic and the mechanic called and said the oil cap had been left off, he found it on the engine. I said, "what yeah that was what happened to it to begin with." He said it was laying on their just now when he opened the hood. My son had forgotten AGAIN to put the oil cap on.
The car was not drivable, had a lot of knocking and I sold if for $500 to an elderly man knowing what had happened to it and he still bought it. I had tried different additives but nothing seemed to work.
The other day we were finishing an oil change on his 2017 Rogue and he said wait, before we closed the hood, I have to touch the oil cap before I can close the hood, LOL! Expensive lesson for him.
My Dad made my younger brother rebuild the engine on Mom’s 69 Volvo, after he didn’t check the oil, and grenaded the engine. Went to the wrecking yard and bought a core, had it machined and then made him pay for everything and made him do all the work.
He was pretty religious about pre-tripping things after that.
   / Stupid Things I Have Done #385
I failed to install the oil gasket in my 1954 Willys as a teenager back in the 70’s. It has a drop-in canister/cartridge on top of the engine. (Fram C-3 😁) I can still see remnants of that goof under the hood almost 50 years later. 🥹🤣 Oil spewing everywhere thanks to the radiator fan whirring away.
   / Stupid Things I Have Done #387
Pretty stupid, put my 13+k class C on my old "trusty" ramps ive had since cobbling my beaters together in high school there 30 or so years old. They have gvwr of 8k I guess not front axle weight. Cause I'm slightly less reckless as I get slower I put jack stands under the frame rails chock the wheels etc. Couldn't get one stand out noticed the one ramp bent and buckled resting the frame rail firmly on the jack stand ramp now rocks like a rocking chair and is a few inches shorter than it's companion sxs comparison. Lesson I learned was don't grossly exceed weight limits on tools and follow safety protocols as backup they work cause I'm not a pancake lol. Immediately bought 16k gvwr rhino max ramps for future repairs requiring me to crawl under something heavier than a lawn tractor.
   / Stupid Things I Have Done #388
Not good. After having bent a few steel ramps changing the flip shaft on my M9 cab and my 1 ton pickup truck adding to the deformity, I built my own from .60 retention 2" thick planks with 2" thick sides. So far so good but they are a bit on the heavy side. I like plenty of loft so when I swap out the pto shafts, none of the hydraulic juice runs out.
   / Stupid Things I Have Done #389
One of the many stupid things I’ve done happened while cutting wood shed rafters with an old electric miter saw. I had been cutting for awhile while listening to the radio and just kind of had a rhythm going as far as cutting loading and unloading the saw. l mindlessly made a cut and reached in to grab the scrap piece and put my wrist right into the blade, as the plastic blade guard had broke off probably 20 years before.
I felt my wrist hit the blade but there really wasn’t any pain. I looked down and saw a huge gash with a nice saw cut part way through one of the wrist bones along with a whole lot of other stuff, before the blood started to flow.
I found out the artery going through the wrist pumps quite a bit blood! I ended up getting the bone, artery, 5 tendons and a bunch of nerves.
Ended up with limited wrist movement, some really stiff fingers, no feeling in a couple of fingers and limited feeling in two more.
Good thing is I still have both hands!
   / Stupid Things I Have Done #390
Id like your post but I won't because that is nothing to like at all... I watched my late dad cut 3 fingers off with a radial arm saw when I was a kid. I took the severed fingers and wrapped them in a paper towel with ice and mom took him to ER. They reattached 2 of the 3 but they were never the same and he got real bad arthritis in his hand after that.
It was his left and he was right handed but it really impacted his job. He was an analytical chemist and had to work around his disability.
So far I've been lucky with farming and managing my welding and fabrication shop but I'm always cognizant (or at least make an attempt to be) when working around machinery and welding equipment.
   / Stupid Things I Have Done #391
About horses; in 1900 when horses were the main mode of transportation there were many horse accidents.
In NYC for example there were more deaths to humans by horses in 1900 than there are deaths by cars today per capita
   / Stupid Things I Have Done #392
I’m left handed and luckily cut the right. The right thumb and forefinger are the ones with no feeling so handling small things with them is tricky.
I remind myself how much tougher it would be with only one hand.
   / Stupid Things I Have Done #393
Nailing in floor joists nail blew out the side of the joist right into hand holding the joist. A piece of electrical tape stopped the bleeding back to work lol Lesson learned don't hold the joist your nailing with hand right next to header. Much more recently don't try to be a tough guy and try to use a 18" chainsaw like a 14" top handle. Thankfully only a Minor injury taught me that lesson. Finally when using a stump vise to field sharpen a chain don't try pounding it in off the center of a stump of freshly cut hard wood. Filing away the chain vise popped out saw and vise hit my leg even slightly dull chains not spinning on a saw rip skin grotesquely.
   / Stupid Things I Have Done #395
Very similar story here, but it was me watching my FIL pull cutoffs off the table saw by reaching between blade and fence, and trying to find the gentlest of ways to tell him (twice!) that he was going to cut a finger off doing that.
Then he did!
I drove him to the ER and sat there eating my lunch (egg salad sandwich on toast) while they sewed him back together next to me. At one point, the surgeon looked over at me and said, "boy, you sure aren't the queasy type, are you?" :ROFLMAO:
   / Stupid Things I Have Done #396
The issue with any chainsaw is when the angle of trajectory is your face. Kind of like a hard recoiling hand gun and your face. I always make doubly sure my face isn't in a direct line with anything that can hurt my handsome looks... :rolleyes:
   / Stupid Things I Have Done #397
I'm not anywhere close to a perfect a'hole myself and I have a nice scar right across the top of my left kneecap that took 108 stitches to close and I will say that 404 sharp chipper chain does a really clean incision. Had a Maalox moment some years ago and forgot my Stihl 075 didn't have a factory chain brake. Bucked a big round, propped my left leg up on the cut round and rested the saw on my left knee. Didn't feel a thing at first but my climbing boot was feeling wet and I looked down at the bloody mess and my torn jeans (should have been wearing chainsaw chaps but I didn't, another stupid decision on my part) and split the cut jeans and looked right at my kneecap and what you think bones should look like, well that isn't true, they aren't white, they are off white grey... Drove myself to the local ER leaking blood on my truck's floor and got it stitched up. Interestingly, I learned there are no nerve endings in the epidermis on your knee cap so I got to watch the ER doctor stitch it up, actually carried on a conversation with her while she was sewing me. I have a dandy scar to remind me of my stupidity.
I'm much more careful about what I do now as I have a 'trophy' to remind me.
   / Stupid Things I Have Done #398
My uncle had really good luck with a bucking chainsaw. It took his glasses off his nose and the next year it cut his shoe laces. Both times he needed a few stitches but he decided a couple of butterfly bandages was good enough.
   / Stupid Things I Have Done #400
Passed the back of my hand under the tip of a cutting torch grabbing at a piece of falling steel once. My first impression wasn't pain, but the fact that my hand had the same coloring a chicken breast has after the first couple of minutes in the frying pan. Not one of my smartest moves.
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2022 TAKEUCHI TL8R2 SKID STEER (A60429)
2022 TAKEUCHI...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2352 (A60432)
2352 (A60432)
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
