stumps vs. bx2200
/ stumps vs. bx2200 #1
skipperbrown
Platinum Member
Pensacola Fl, Birchwood TN
Kubota b2650, bx2200, L3940 (gone), New Holland FWD TN85, RTV 900
This is a 4" dia. sycamore tree that I have been wanting to get rid of for some time. I cut the tree down and left about 2' of stump. I pushed the stump at the 2' level w/ the fel from 3 sides and the stump gave up. Took maybe 3 minutes. I have sandy soil. I was impressed.
BX2200 1, Stump 0
I love my 'bota.
mark
/ stumps vs. bx2200 #2
Nice picture. Are those bucket hooks mounted inside the bucket? Interesting position. How do they work?
/ stumps vs. bx2200 #3
FEL sure does make those jobs a lot easier. /w3tcompact/icons/wink.gif
/ stumps vs. bx2200
Yes. I drilled 4 holes and put the hooks on a 3/8" SS u bolt w/ a ss strap on the other side. This is a light duty setup as the threads take the whole load. However, each hook should be able to handle at least 200-300 lbs static load. I've only used them to pick up a 100 lb. tree and as a tie down point to hold brush in the bucket. Work fine for that duty. My idea was to have sometime to handle railroad ties for landscaping which weigh about 200 lbs max for a good solid one.
If I did it again, I'd move them in another 3 or 4" inches b/c they are really close to the bucket edge when you hang the chain. I'd move them if it didn't take so long to drill through that bucket. It's about 1/8" thick and takes a while to drill even w/ a sharp bit.
mark
iDrive TDS-2010H...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
