Stump grinder project - need some input
/ Stump grinder project - need some input
Those of course started as bar stock before being turned.
Frame taking shape
Dry cut saw doing one thing it does really well
I use a temporary pin to hold things in alignment for welding
This is a different view of the hub flange before being assembled to the splined sleeve
That's pretty much it for build pics.
/ Stump grinder project - need some input #44
IMO that video demonstrates vertical bounce caused by trying to cut too "vertically".
My preference is to cut DOWN into the stump, I probably take more levels and reposition the tractor more than most people do, but I only cut with the blade in the wood between about 5 and 7 o'clock - nowhere near the 8 and 9 or 4 and 3.
{For those who still remember analogue clock faces}
Reg, that video shows a healthy depth of cut (around 2" per pass) in a stump that covers from 4 to 9 o'clock (or better) in some areas. The "bounce" is fine with me. I have hundreds of stumps to grind, so I'm putting my 50+ PTO ponies in the wood is how I plan on making that happen.
/ Stump grinder project - need some input #46
Sure, I know and agree with the "more tool in the material" principle (-:
It may just be a personal choice and local conditions vary a LOT.
For what I have ground here with what I use and how I work (several variables right there).
I have found that TOO MUCH bounce can be a problem if/when the grinder hits a really hard spot on the way back down.
Clutch slip and/or stalling the tractor - - assuming I am already running close to max power I can put to it.
So my PREFERENCE is to avoid bounce, typically by limiting my cut to the bottom of the arc.
Sure, it takes a few more passes, but I'm not getting shaken to bits, I'm not breaking teeth, I'm not stalling the tractor, burning clutches, etc.
and when I get to a rock it is usually a light touch instead of hooking under it.
I've been fortunate that I've only found smaller rocks thus far. That stump was causing hop because of how much of the wheel was in contact. I was down in the middle of a large stump, so the aft cutters were trying to lift while the fore were trying to pull down. You can see me stall the clutch in the video. If I run 300 rpm faster, it'll stall the engine (found that out in a bigger oak after adjusting the tension a little tighter) - so I think I've got a good "tune" on my twin disk clutch. The gearbox actually warms up slightly where it didn't where I had been running it. Hot clutches, and cold gears.
I wish I had some cutters deeper into the exposed side of the wheel for my aspen trees. Those are so soft, I could scrub them off in a couple passes if I didn't rub the wheel above the teeth.
/ Stump grinder project - need some input #48
I hit a steel culvert that was long since buried on the property with the stump grinder. One greentooth has a big chip in it now but I have not ordered a replacement (Just turned it over to the next sharper side). Have not hit much more than a 4" rock that I know of but it didn't stop the machine.
3 Brake Drums (A62613)
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
(2) UNUSED 10-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 10-16.5...
(2) UNUSED 12.4-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12.4-24...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
(3) 6"X34'-1/4" THICK STEEL TUBING (A64280)
(3) 6"X34'-1/4"...
