Stump Bucket
/ Stump Bucket #1
mangus580
Western, NY
Bolens (Iseki) H1502; LS R3039
Had a friend text me on friday about a stump bucket a coworker had for sale. I went and checked it out yestarday, and I think its too big for my R3039 to really work effectively...
I can get it for $250... It appears to be about 42" from the mounting plate to the tip of the teeth.
Any thoughts?
/ Stump Bucket
I do not, but it didnt take much effort at all to stand it up between pictures.
I am more worried about the length and overall width. Also, the lack of teeth up the sides for ripping roots.
/ Stump Bucket #8
I think it is worth the money. You could always cut some sawteeth yourself with an angle grinder and a cutting wheel. Just my 2 cents.
James K0UA
/ Stump Bucket
Thanks TSO I thought I had seen one like it before.
I think your post shows I should pass, and find one thats a better design.
/ Stump Bucket #13
I am looking for a stump bucket also, I have a few 16" stumps to remove but mostly small trees and lots of thorn bushes and some concrete to pop out and remove. Do you think my R4041H can handle any of the following?
Stump Bucket for Skid Steers | Blue Diamond Attachments
Skid Steer Stump Bucket
Product Navigation
Loflin Fabrication
They all look heavy and well built , what do you guys think? If I take it easy and cut & dig the roots can my loader handle it? Thanks
/ Stump Bucket
I think the issue you will have is with the overall length. All 4 of the buckets you shared are quite long, and I think with the inadequate curl feature the LS is semi-famous for will be nothing but a headache with a bucket thats 5' in length.
The one I linked above, while it doesnt have as much 'ripping' teeth on it, is only about 40" long and 16" wide at the tip. I think that is a better size ration for a tractor in our range....
Product Navigation
Loflin Fabrication
/ Stump Bucket #15
it just feels to me that the system goes into relief way too quickly ... I wonder if the curl relief could be adjusted. Another thing that might help would be moving the curl cylinder pins higher up on the QA plate, I've been debating that for awhile.
As for the bucket, after putting HOURS into using that one, I truly think that something around 40" long or less, with about 6" of width or less at the bottom, would be much more practical on this machine.
/ Stump Bucket #16
. . . As for the bucket, after putting HOURS into using that one, I truly think that something around 40" long or less, with about 6" of width or less at the bottom, would be much more practical on this machine.
I've got the Wildkat Stump Grapple, and I think I agree with you. I'm using mine on my Kioti DK50, but there's not much difference between it and your tractor. I think these stump buckets work a lot better on skid steers, which have the power and hydraulic capacity to put them to full use.
I like mine ok, but mainly because of the grapple function. I quickly figured out that digging out hundreds of cedars with it was going to be way too long of a process and would possibly damage my FEL. Rather than tear up a $5,000 FEL, I bought a Kubota BX23 so I could use a backhoe on the ones I can't push over. It's still a long process but not as long as using the stump grapple only, and it's way less stressful on the FEL.
One of the huge differences in using the backhoe vs the stump bucket is being able to see what you're doing with the backhoe. Same thing holds true on using the stump bucket on a skid steer vs. on a tractor. Besides having more power, you can see what the stump bucket is doing on the skid steer.
/ Stump Bucket #17
So you are using the Skid Steer Stump Bucket | Spartan Equipment. ? Have you seen a shorter bucket (40") with a narrow tip (12" or less) anywhere? I am a newbie and I sure appreciate all the great info & advice I get from you guys. As a fellow Michigander I can really relate to your experiences.
/ Stump Bucket
He had a bucket just like the one in my original post.
2000 Generac 2000 Series 30kW T/A Towable Diesel Generator (A59228)
2000 Generac 2000...
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
John Deere 6125R (A60462)
John Deere 6125R...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
