studs for ice?
   / studs for ice? #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Anyone using removable ice studs on their R1's for snowplowing?
Advantages, dis-advantages vs. chains.
   / studs for ice? #2
I prefer chains, they are good in dirt and some mud, too. I put them on once and never look back until one comes off. But they are heavy.
   / studs for ice? #3
I've always used chains if added traction is required. Chains will provide traction on frozen dirt/gravel driveway. Studs - not so much. Studs would be best on a very hard/smooth surface - concrete or asphalt. Studs will provide less surface damage.
   / studs for ice? #4
I put screw in studs in my R4's - they seem to help with the thin ice and don't tear up the asphalt like chains. I've left them in for 10+ years with no ill effects.
   / studs for ice? #5
I put screws into the lugs of the R1s I had on the Gravely but never got to test them out, as I sold the Gravely.
It had chains for the turf tires it had.
Ralph
   / studs for ice? #6
At the cycle shop, we put screw in studs in the fork truck tires so we could safely unload trucks while on ice. They made a huge difference and rode just as smooth as before. If you spin, they will leave scratch marks. If you are climbing through a woods and you need traction, chains are better. If you just need help on that polished packed snow or ice, the studs will really help.
   / studs for ice? #7
I was planning on studs for the new LS last year but did not need them. No way I want to wrestle with chains as I am 70 and I have oversize turf tires. If I encounter traction issues, I will use studs and leave them in year round.
But I have no slopes to deal with.
   / studs for ice? #8
If you pull out the studs each season you will find the holes are quickly plugged with tiny rocks and dirt and you will end up drilling new holes next season. Eventually you get swiss cheese for tires. I'd leave the studs in.
   / studs for ice?
Do you stud the front tires as well? Seems like with R1's, studs would help with snowplowing.
   / studs for ice?
Seems like aggresive R1 ag tires with studs would be the cat's meow of tractor snowplowing. The R1's have really aggresive threads that will bite through deep, loose snow, and the studs will then bite through the ice. I like the idea of leaving the studs on all year. I have lots of shale which slice the R1's. Studs might help with that too.
Soil Mover Scraper (A50514)
Soil Mover Scraper...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
