studs for ice?
   / studs for ice? #11
chuck,
When I bought my tractor I asked the dealer which tire was best for snow/ice. He recommended turf tires. My area gets 120-140" of snow a year.
I only plow light snow falls of less than 4 inches and use the plow to back drag around the garage, house and tight areas. The inverted blower gets most of the snow duties. One method I use is to angle the blade and windrow the snow to the center of the drive and then run the blower down the center. Keeps the hours off the blower and it is easier to monitor the front than the rear.
I am not pushing large amounts of snow with my front blade set up.
   / studs for ice? #12
I’ve also been thinking about adding studs for snow plowing. I road a lot all year so chains are out. R1’s don’t do so well on the packed snow roads here. I was curious about leaving them in all year, like was mentioned having to screw in a different spot every year may end up causing the tire to wear much faster?
Grip Studs were the ones I was looking at. I though their price was fair.
Now to really decide if more salty road driving to plow a few driveways is worth it...
   / studs for ice? #13
I would love the idea. Except for my concrete aprons and building floors. And removing them would simply not be an option. Enough stuff to do every year, seems like no time at all between seasons as you get older.
   / studs for ice? #14
   / studs for ice? #15
Studs are great, or at least waaay better than no studs. You can't beat chains for raw ice chewing but they will also quickly chew up and mark pavement. Studs will only scratch it IF you spin your tires and will not damage it or concrete if you're just rolling across it. I took my front studs out the first year and like others said, it leaves a hole in your tread. I have them at all 4 corners with 4 in each set of "bars" around the tire. About a buck each.
   / studs for ice? #16
A lot of people ask me about tires for plowing snow and possible chains. I have put on chains for spreading manure in non-cleared land but for the most part if your snow removal system is working you only need surface contact and seeing most people driving over where they plowed it doesn't take some fancy lugs.
   / studs for ice?
I don't know, I might get chains for the rear tires and stud the front. I don't think that should promote front axle damage like some people say front chains will. I've been plowing for the past 5 years with nothing but bare R1 ag tires.
   / studs for ice? #18
I put good quality, spiked, tight chains on all 4 with R4 tires. The first year I didnt have them, the tractor worked well in the snow. As soon as the snow was compacted and turned to ice, on my steep driveway, I found myself sliding down it sideways. Not exactly my idea of fun when there are large trees that line my road. I dropped the money and bought the chains. Love them. Stick like glue, no issues with the front axle. Its a rougher ride, but better than sliding.
   / studs for ice?
What kind of chains did you get?
   / studs for ice? #20
Here is exactly what I ordered. Tirechains.com Duo-Ladder V-bar combination for the rear and V-duo V-Bar for the front.
2025 GPS Trailer (A56858)
2025 GPS Trailer...
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
Mini-Excavator Heavy Duty Grapple Attachment (New/Unused) (A59225)
Mini-Excavator...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2006 Mercedes-Benz Unimog LWBTruck (A56858)
2006 Mercedes-Benz...
