Stud welder
/ Stud welder #1
Mysfyt
Platinum Member
NE Wisconsin
Kubota L3901
Looking into buying a stud welder that would handle up to 1/4". There seems to be three levels of them. The cheaper auto body models, the capacitive discharge for around $2000, and the top end that goes for 4 grand plus.
I'd like to say it would hardly get used, but once you have it you start finding more uses for it. Thus, the cheaper units may not be the way to go. Looking for opinions from people that have them. Thanks!
/ Stud welder #2
Can I ask what you are planning to do with the welder? I'm assuming that if you are looking for one that can do up to 1/4" then you are not talking about sheet metal repair. I have no advise to offer as I've only seen body repair ones being used by others. I did see one that would weld studs with rings on the end. It allowed for a steel rod to be slid through all the rings so instead of a slide hammer pulling on just one stud you could pull on a bunch all at once. I think he called them keys. But I'm thinking that you're looking to weld things like threaded studs.
/ Stud welder
I'm making a control panel and the print calls out #10-24 studs.
/ Stud welder #4
I've made a lot of control panels. I used to work for a panel shop. I have never seen a stud welder used on one. The manufacturers of the enclosures use them for back panel mounts and such. Are you building the actual enclosure or modifying one?
/ Stud welder #5
I have one of the auto body style stud welders and if you could get threaded studs that would work, it would be fine for #10. Locating them with precision wouldn't be that great though.
Whenever I needed something like your describing I always used self-clinching studs. They even make them flush mount so after powder coat you couldn't tell the difference between them and a welded stud anyway.
50 of them 10-24x7/8" will cost you about $10.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
