Stuck yanmar 165D
/ Stuck yanmar 165D #201
When I unloaded the tractor, the loader worked perfectly. I drove the tractor around for about 15 minutes and then the valve handle stuck and started acting up. Got the valve handle unstuck, but now it just moves down slow, as in like an inch in 5 seconds
That sounds a lot like a piece of debris got dislodged and stuck somewhere, either in the valve, or in the reservoir as @rScotty suggested. A not uncommon thing to happen after being trailered in my experience, and not just for tractors.
All the best,
Peter
/ Stuck yanmar 165D
What can I do about the control valve?
/ Stuck yanmar 165D #203
Can you post photos of the back and bottom of the control valve? Most valves have ports that can be unscrewed to clean the passageways, but without seeing yours, it is hard to advise, beyond get the control valve absolutely clean, as in "open heart surgery clean" before opening anything. (Scrub off, pressure wash, brake cleaner plus scrubbing, wipe with clean cloth. Then start to open a fitting, and hit the first few threads with more brake cleaner, and a cloth if necessary. You can't be too compulsive about this in my book.)
All the best,
Peter
/ Stuck yanmar 165D
/ Stuck yanmar 165D
As far as power steering there have been many conversions done to Electric Power Steering a popular part is the 02-07 Saturn Vue unit with an aftermarket control unit, such as;
02-07 Saturn Vue/Chevy Equinox Electric Power Steering Motor Complete EPAS/EPS | eBay
with something like this added, it can be done without this though;
These were put on some yanmars?
/ Stuck yanmar 165D #206
People who DIY, yes.
Some of the MTD Cub Cadets tractors have them too. This works for the SCUT machines as they are smaller.
Even old small tractors like this Farmall.
/ Stuck yanmar 165D
Hmmm, I'm kinda interested. Gotta get the hydro fixed first
/ Stuck yanmar 165D #209
Whoa! I can not believe how quickly this thread turned.
It went from a stuck engine due to prolonged inactivity with Every sort of "do this , do that"
To
It then turned it over to a REAL mechanic! (page 13)
and in less than three posts...to Tire selection.
Damn, the internet is a mile wide and an inch deep.
Might have to give up on it all together.
But then where would I get my chuckles?
/ Stuck yanmar 165D
I guess this thread can be stopped then
/ Stuck yanmar 165D #213
Other than the huge repetition of suggestions from people clearly not reading even a post above them, I appreciate the thread as I like to see someone's journey in getting a brick turned back into a functional tractor... a task that while I'm not likely to undertake myself, there are definitely parts of it that many of us will encounter on our own journeys.
I for one look forward to seeing @millard762 happily using the tractor to the fullest in the future - please keep posting!
/ Stuck yanmar 165D #214
To
To me it's a work in progress, and things will change as progress is made in one area and then something else comes up.
2025 Miscellaneous Mini Excavator Attachments (A61572)
2025 Miscellaneous...
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
2015 Ram 1500 Pickup Truck (A61573)
2015 Ram 1500...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
