Stuck yanmar 165D
   / Stuck yanmar 165D #11
I would not be adverse to sitting piece of 2x on the piston and giving it a good rap with a hammer.
   / Stuck yanmar 165D
Clutch works fine. I have not drained the oil yet. That will be on the to do list. I have to get a filter for it and will probably just use some Mobil delvac I have on hand to replace oil with when I get to that point. I may let it sit for another week before I do anything more to it. I will try getting at the flywheel and advancing it that way if possible in a week or so, if that doesn't work, I will pull the head again and start tapping.
   / Stuck yanmar 165D #13
Your going to need rings. Since the clutch isn't stuck. Don't break a piston!! Try moving the fly wheel through the starter before I would go beating anything. Quite aFew times............
   / Stuck yanmar 165D #14
Or just tow it and bump it with the clutch while in high gear.
   / Stuck yanmar 165D
I figured I would buy some rings and maybe a 75mm hone to knock off any buildup that could be around potential rusted rings. I tried popping clutch in 6th gear to no avail, however when I did it I was on gravel and not pavement
   / Stuck yanmar 165D #16
That's a good enough try in my book, and I think rings and a hone might be prudent, but I would consider pulling the oil pan while you wait for the filter to see if there is anything visible there.
Sometimes tractors get parked for a reason...
All the best,
Peter
   / Stuck yanmar 165D
Well, I just pulled the dipstick and I am starting to smell some of the ATF/xylene mix in the oil. Just a faint smell, so it is starting to work it's way down.
   / Stuck yanmar 165D #18
Broken Ring! Normal.
   / Stuck yanmar 165D
Here she is
   / Stuck yanmar 165D #20
have you tried to rock it back and forth with the socket on the crank shaft?? do it gently believe back and forth motion will bring results
willy
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
Takeuchi TB216 (A57148)
Takeuchi TB216...
2020 CASE SV280B SKID STEER (A52709)
2020 CASE SV280B...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
TAKEUCHI TS50R SKID STEER (A52709)
TAKEUCHI TS50R...
1774 (A58375)
1774 (A58375)
