Stuck injector
/ Stuck injector #1
Cord
Richfield, Wi
Resident Architect
Trying to pull out the #3 injector in my Deutz 1011. Let's say that it's slightly stuck. Heat and penetrating oil have not been effective. With the puller tight, we even tried hitting on a head bolt to drive the engine down. Ended pulling the ferrel off the cable and the injector hasn't moved. At this point I'm trying to get my hands on a hydraulic puller. If that fails, I'm probably gonna have to pull the head.
/ Stuck injector #2
Pull the head. It's an opportunity to measure cylinder bore wear and replace the head gasket . It could be 1/2 rotten from old coolant with expired corrosion inhibitor.
/ Stuck injector
Well... I tried one more time to get the injector out over the weekend. I figured I'd try heating the injector and then hitting it on the side with the air hammer to try and break it free. Well... things didn't go according to plan. The injector return lines were covered with a cloth fabric that holds the grease. I brushed past the line with the torch and it lit right up. The fire was pretty small, but I didn't have a glove on so I couldn't grab the flame to snuff it out. No water or a shovel was near by either. I went to grab a bucket and some water, but realized the barn water was shut off because it had froze the night before! By now the machine was smoking pretty good and the fire was into the belly pan. The machine was only 10' from the barn, so I called 911. The cop came first and I asked him for his extinguisher. Pulled the pin and as I was walking up to the machine something popped and the flames reached up to the top of the lift arms. I gave it the entire extinguisher but it didn't put the fire out. Now the fire was on the gravel under the machine so a fluid must be burning. By now a second sheriff was there and we hit it with a second extinguisher. Still wouldn't go out, but it was knocked down. I left to grab a garden hose and a third cop had arrived and was pulsing his extinguisher to at least keep the flames knocked down. I was able to get a garden hose strung out and the wife turned the water on. Felt like it took an eternity to purge the air out of 300' of line but once I had water I was able to get it out. It was at this time that the volunteer fire department came and they used the brush unit to really wet it down.
Once everybody had left, I called the insurance company and told them they needed to get the machine towed because it was leaking fluids. They said an adjuster would be calling but that they wouldn't pay for the tow until he had looked at it. Checked on the machine an hour later and there was a 20' plume of fluid running into the grass. Knowing it had 32 gallons of hydraulic oil and diesel on board I called a environmental clean up company. They sucked the tanks dry, threw down some oil dry and covered the plume with some plastic so the rain wouldn't spread the spill. He figured the clean up will run around $7,500 because they had three guys on a Sunday. They'll excavate the contaminated gravel during the week after the insurance company approves the remediation and when their labor rates are lower. The spill amount was well over the limit so it got reported to the DNR as well. The clean up guy warned me that the insurance company would try to deny the remediation claim so I'll probably have to fight them. They should have just towed it, would have saved them a bunch of money.
At first I thought the machine was a total loss, but now that I'm looking at it, it's actually not all that bad. Only the left side of the engine burned and it looks like the hydraulics are still holding pressure (edit - I now believe the curl is bleeding down). Obviously the wiring is gone, but it looks like some new fuel lines, maybe a dozen hoses, a new battery and the machine would be functional. Never burned the paint and the cab is untouched. The starter and alternator are both on the opposite side. Think it's repairable? I didn't take any pictures of the engine compartment so I'll try to get some tonight.
What's the machine worth? Gehl 6635DX, 1999 year, 3250 hours, bald solid tires, enclosed cab, heater, suspension seat, led lights, backup camera, single speed, high flow. Machine is in pretty good shape and we just went through the entire hydraulic system with new drive pumps and lift cylinders.
/ Stuck injector #6
Hope it works out for you.. your status makes it seem like not too much needed to get things going again, but you still have the original problem.
/ Stuck injector
I talked to two people today that confirmed the return lines burn like a fuse. That's exactly what I saw when the fire started. Ironic isn't it? The other thing that I noticed was the nylon chaff guards on the hoses also burned really well. In all honestly, I don't think it's burned all that bad. All the damage is limited to the left side of the engine. The paint isn't burned off and there is absolutely no damage to the right side of the engine or to the cab. The dealer's initial estimate was $7-9k for the fire damage and 10k for the engine. The machine was insured for $20k so that'll total it. I'm just not certain they'll payout for the full value or some amount below that limit. If it goes too low, I don't know if I can replace it with a comparable unit. That would suck. I'm kicking around the option to repair it myself. Really depends on the payout and what the by-back amount would be. I know on past claims they wanted 50% of the payout amount for the buy-back and that's just insane. I've already confirmed that I can get a reman'ed engine for $4850 which is half the dealer cost. Honestly, I don't see $5k in burned hoses and wiring. Thoughts?
/ Stuck injector
Well, the estimate from the dealer is $3,300 in parts and 80 hour for $7,360 in labor. Last week the insurance company tried telling me the machine was only worth $10-11k. It's actually closer to $14k. It was insured for $20k. At this time I don't know what they're going to do.
/ Stuck injector #10
There is no anti-freeze in a Deutz. The hyd oil flows through the motor. Some people call it "air cooled", which is not accurate either.
/ Stuck injector
I've been really getting familiar with the engine and it has an incredibly complex head casting. They do cool the engine with the motor oil. However, they also offer the engine in an air cooled version. The weird thing is that they must use the same head on the oil cooled engine as the air cooled engine. Most heads are "solid" with smooth sides. This head is like a piece of coral with pockets and passages that interconnect each other. If I poured water on the head, it would flow from one end to the other. Weird!
Got confirmation yesterday that they are going to total the machine. At this time, I don't know what the buy back amount would be. They're going to send the photos out to some salvage yards for bids and then I'd have to match the highest bidder if I want to keep the machine. At this time, I'm not certain if I even want to buy it back. I've put a lot of work into it and I now know that it's mechanically sound, but I also know the engine has water in it from when the fire was put out. Engine definitely needs to be replaced. I crunched some numbers last night and I figure that if I can buy my existing skidsteer back for $3,500 I could then repair the damage using new parts and replace the engine and still be ahead by $1,500. There is another machine that's local to me with 1/2 the hours and it's a 2-speed with the asking price equal to what the payout would be. The getcha is that it doesn't have the controls that I like, but my machine does. If there was some way that I could swap controls, I could end with a newer machine.
/ Stuck injector #12
I hear ya, I almost did the same thing on my loader. I have cable controls on my loader going to the hand controls. The new ones are electric over hydraulic, so I keep fixing mine. That is if I stay with Bobcat any way. Not a fan of bob cats new machines, specially because they won't let me have the software so as I can fix it myself. I have broken both axle so foot controls are out. I like cats pilot operated hand controls. The say they are not as fine of a control as what I have or the electric over hydraulic. Have not tested either myself. I have not looked at what Gehl has for controls. I know if I had to change it would be like having to learn how to walk again.
Deutz's stuff is neat, still not a fan. That Kubota engine I have is tough to beat, if i went to a cat loader it looks like the have a mitsubishi engine? I would have to have something like what happened to you before I would replace it. Told a friend of mine that wanted to use my loader, "I would rather loan out my wife", "I'll come over and do what you want but you ain't touching it" Best of luck!
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
John Deere 7000 4R Planter (A66408)
John Deere 7000 4R...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
