Stuck Dozer - Help
/ Stuck Dozer - Help #42
Bring in the neighbors dozer and pull it out.
/ Stuck Dozer - Help #43
I'm sure you could play a tune on that wire. :laughing:
And I'm really curious how that Cat got down there in the first place. No excuse would be good enough.
stuck on purpose for training exercise?
/ Stuck Dozer - Help #44
No, I think some of those guys are dumb as rocks with the equipment. When I was active duty I saw my share of dumb mistakes. Most don't have enough experience with that kind of equipment. At least they have the heavy duty stuff to bail them out. There's no way I would be standing around that cable, either.
/ Stuck Dozer - Help #45
Agreed, I can't imagine anyone driving in there, unless their intention was to either get stuck, or cause chaos.
Update:
Well my neighbor is still waiting on the neighbor's brother with the wide track dozer. I know if it had been mine, it either would be out or completely buried from trying.
Sent from my iPad using TractorByNet
/ Stuck Dozer - Help #47
Wow it's still stuck? Hope you get it out.
Chad
/ Stuck Dozer - Help #48
While waiting I'd get a spade and dig a trench (or 2) at least a couple of feet deep to drain water away from the tractor.
A bit of an update... Quote of $1500 to get it out. No date to do so as the property owner giving access has stated he wants to be present, but has been ill. Unfortunately, the Cat owner is going back to the mainland 1st week of July, so time is fleeting.
David Sent from my iPad using TractorByNet
/ Stuck Dozer - Help #51
sounds like if enough time is given, it will up enough you can just drive it out?
/ Stuck Dozer - Help #52
u dont need to chain a tree to the tracks when i was young the old man got a cat 943b stuck he put trees under the tracks use the bucket to lift mach up u may have to put old wood or stones under bucket after its raised up so it dont get stuck far down in mud trees about 8 inch round will work
I rented a large Cat dozer a few years ago and nearly had a coronary after getting the machine swamped worse than this one. I used the method described by Case above. and it worked well.
Lowering the bucket to raise the machine allows putting logs under the tracks so it can run itself out of the muck. Some work involved and seems simple but it does wok. Good luck.
/ Stuck Dozer - Help #53
sounds like if enough time is given, it will (dry) up enough you can just drive it out?
With the weather patterns the way they have been recently, I'm pretty sure drying out is not an option. He's in Ninole on the wet side of the Big Island. They get as much as 200" of rain per year and that is the average/normal. They have had 4" this month so far and 13" last month. The last couple of years were what we call "drought years" but Ninole still got 140" last year. When we say it's the wet side we mean wet.
Hello neighbor
Well, only 87.5 so far this year, seems like it has been a strange one.
Rumor is, they might get it out this week, all the players may be in place.
I keep telling my wife, that if it were ours it either would be out by now or have a marker for where it's buried. LOL
Well today was gonna be the day. The retrieval dozer is on site. Unfortunately once the batteries were put back in, the stuck machine wouldn't turnover, possibly bad starter solenoid. Replacement on the way.
Maybe tomorrow. :)
Loader was unstuck that same afternoon and pulled up the near to resting area near the house using the wide track dozer in previous pic. Unfortunately, I was not able to observe and get a pic. :(
Thanks for all the input.
Double post :(
/ Stuck Dozer - Help #58
Very glad to hear you got it out okay. I knew the extra dozer would be the best bet.
What ever happened to the two guys that got it stuck in the first place? Are they still basking in the sun in Hawaii?
Yep, that was the ticket.
Last I heard they had complained about not getting paid and the neighbor wife was headed to bank for copy of the cancelled checks.
Interesting aside, one of the neighbors involved in the recovery told me he had recommended against purchasing that loader for that property saying a wide track dozer was the right machine for the work intended.
/ Stuck Dozer - Help #60
Could you get a heavy wrecker on top of the hill to winch it out they usually carry 200 feet of cable
2012 DODGE 2500 RAM (A65643)
2012 DODGE 2500...
2023 SANY SY225C9C5KL EXCAVATOR (A63276)
2023 SANY...
78" QA Heavy Grass Fork Grapple (A64127)
78" QA Heavy Grass...
Goodyear 480/80R46 Tire and Wheel set (A65640)
Goodyear 480/80R46...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
