Strecthed drive chain - remove a link?
/ Strecthed drive chain - remove a link? #1
marks
San Luis Obispo, CA
JD 870
After some heavy usage with my DR mower, the #40 drive chain has stretched beyond the capacity of adjusting. Fort the next two months I anticipate further usage in heavy brush on steep terrain, is there a possible concern in just removing a link from the chain?
Thx
/ Strecthed drive chain - remove a link? #2
I don't think it would be a problem. Hose reels on fuel trucks use a chain driven system and I have often shortened the chains when they get loose due to chain and gear wear. When and if you do shorten it, you can get full and 1/2 link's. Pick up some of each so you can get it adjusted as close as possible. TSC usually has a good selection of chain master links.
/ Strecthed drive chain - remove a link? #3
Check the sprocket fit of the chain. If the chain is loose after a only a few teeth on the larger sprocket it should be replaced unless it is a slow moving chain. A slow chain is very forgiving. A fast one should fit the sprockets well. A worn chain wears spockets and thereby shortens the life of chains replaced without a simultaneous sprocket change. A slow chain can literally be run until the sprocket slips. Not a fast one!
Larry
CountyLine 7ft Cutting Harrow (A65579)
CountyLine 7ft...
Woods PRD7200 6' Finishing Mower (A66408)
Woods PRD7200 6'...
1986 Bumble Bee Fishing Boat (A66408)
1986 Bumble Bee...
Rhino 3-Pt. Forklift for Tractor (A66408)
Rhino 3-Pt...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
2016 Freightliner Columbia 120 Glider Truck, VIN # 3ALXA7CG9GDGZ6492 (A65563)
2016 Freightliner...
