Stihl FS240
   / Stihl FS240 #1
rekees4300
Elite Member
Indiana
JD4300
Thinking of buying a new Stihl FS240. Needed to trim several acres of tall grass/weed/briar as well as clearing up to 3" diameter Buckthorn. Before spending $600+ would like to know if the FS240 would be up to the task. Recommendations?
   / Stihl FS240 #2
I have the predecessor-a FS250. I think it will do what you want. Use the circle saw blade on those 3" buckthorns.
Will
   / Stihl FS240 #3
I also have a FS250. It a very powerful trimmer. With a blade on it will cut though small 3" trees and brush easy.
You may want to look at the FS 130 R $400 it is a great performer.
   / Stihl FS240
Thanks for the feedback guys. For the circular saw blade there are two choices, scratcher tooth and chisel tooth. Which one would be better?
   / Stihl FS240 #5
I use the chisel blade, and I think you'll like it on those 3" trees. It is easy to sharpen with a chainsaw file.
Will
   / Stihl FS240
The FS130 has a great weight to power ratio and is lower priced but I'm leaning toward getting the FS240. According to a Youtube review the FS130 has a 4 stroke engine that isn't suitable for low speed trimming.
Will
Thanks, apparently the scrather tooth blade has to be "professionally" sharpened which would be a hassle so I'll get the chisel blade. Also going to get a 3 bladed brush knife to annihilate briars and other assorted undesirables.
   / Stihl FS240 #7
I have used both blades. Saw blade on 2" to 3" trees and heavy brush. The 3 point blade on thick brush and heavy grass.
If it just heavy grass I use the string line .105 X Line or Commercial Round Line. Both work well.
There is no one blade or line that dose it all.
   / Stihl FS240 #8
Yes- it helps to have an assortment of heads. I have the line, the 3 plastic swinging blade head, a 3 bladed steel head, and the chisel tooth. All get used for something every year.
Will
   / Stihl FS240
Bought a FS240 today. Also bought a chisel blade, a 3 pack of 7/32" files to sharpen it, 3 bladed steel brush knife, roll of .105 nylon line and a gallon of Motomix. Still need to get a special stop limit deflector for the chisel blade. The Stihl dealer said they would extend the FS240 warranty from 2 years to 4 because I bought the Motomix ... can't beat that! :)
   / Stihl FS240 #10
rekees4300, if you get a chance would you post a picture of that "stop limit deflector" used for the chisel blade. My dealer didn't seem know which one I needed for the chisel blade purchase. I bought a FS90 some time ago but haven't used the blade yet. That .105 line can take down about anything except the larger brush and small trees.
Cheers,
Mike
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
40' shipping container (A52377)
40' shipping...
2007 International 4300 Dump Truck (A51692)
2007 International...
2016 Nissan Verse Note Sedan (A53117)
2016 Nissan Verse...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
