steering wheel
/ steering wheel #21
I see he doesnt need to remove it so thats good but wanted to add this bit of advice anyway for the next guy.
I have drilled holes in hubs and gears and threaded them for a good steering wheel puller with long 1/4 - 5/16 bolts in order to remove them.
Sometimes having to leave the puller on over nite or even days and using plenty of PO and pounding on the puller shaft end while under tension will loosen about anything.
/ steering wheel #22
that works, if the hub is wide ebough to drill and tap.
I've seen many tractor wheels where the steel hub itself is only 1/4 or 5/16 webbing.. making it hard to do that. still.. though.. they do cut off easilly.. :)
soundguy
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2015 Dodge Journey SXT AWD SUV (A61569)
2015 Dodge Journey...
2024 Linx EQ07020RS (A60463)
2024 Linx...
18' Field Cultivator (A60462)
18' Field...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
