steering problem
/ steering problem #1
camer
gwinn mi.
i have a l3130 and if you turn the steering wheel slow it doesnt turn the wheels. if you turn the wheel back and forth fast the wheels grab. if you go a little ways and turn the wheel again it doesnt turn the wheels. anybody ever have this problem and know what it could be.
/ steering problem #2
I think that the problem is in the hand pump below the steering wheel. From time to time the cylinder will go bad but the most times it's the hand pump.
I'd be sure the filter is clean or has been changed before I'd be doing anything though.
/ steering problem
i lifted the front end off the ground with the bucket and tried to turn the wheels by hand they turned freely. do you think the cyl. could be by passing.
/ steering problem #4
On the BX series this is common. The seal in the cylinder is most likely bad.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
AUCTION STARTS HERE @ 9AM (A65056)
AUCTION STARTS...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
