Steering a DR brush mower
/ Steering a DR brush mower #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
I'm considering getting a 15hp pro to maintain my property. I've got six foot tall grass on a large level spot, scotch broom on a hill and silal and huckleberry around the perimeter. Most of the property isn't level. Is there anymore to steering than just pushing down on the handles and levering the beast in the direction you want to go? It'd be nice if there was a brake on each wheel you could work so the machine could turn itself.
/ Steering a DR brush mower #2
Hey Mike,
I looked over the DR site, and it doesn't seem like there is any more to steering than manhandling it, like you said. I've never been near one, so can't be sure.
If you're open to other brands and are searching for new, I'd recommend a BCS 853. The 853 has differential lock and steering brakes. When going along a hill, you'll appreciate the fact that you can unlock the differential and ride the uphill brake to keep it on track. Four forward gears. You can get it with a 13 HP Honda or 11 HP Lombardini diesel. You'll never need more power than that. The rough-cut mowers come in 21, 26, 28 and 31 inch It has many more options for attachments than the DR, including a tiller, rotary plow, snow blower, sickle mower, finish mower even a round baler.
The biggest disadvantage to BCS are the fact that the engine hangs out the back of the wheels, limiting how deep of a ditch you can go through. You can buy taller wheels to overcome this, but it's aggravating when it happens. This is not really an issue with any attachment other than the mower in very rough terrain.
Earthtoolsbcs.com is a very comprehensive site to see all the options. Used versions include the 735, 605, 830, 850, and 852.
Thanks Bill, I appreciate the info. They're out of my budget range though. Look like well built units.
/ Steering a DR brush mower #4
Mike;
I have a 17hp DR mower and they don't have steering brakes. I received a customer satisfaction survey from DR and they asked me for suggestions and that was my number one request. The problem is that they already have both handles taken up with the clutch, operator presence lever and brakes. You can man handle it fairly easily because it is well balanced but it's nothing like a machine with steering brakes. On flat ground I usually disengage the clutch and that lets the machine freewheel for easier 180 degree turns. In rough stuff you have to hang on and go with the flow. If you keep the ground speed down, it really isn't that bad. Good luck.
SimS
/ Steering a DR brush mower #5
I had the 17 hp model and sold it for lack of use. My experience was that on hills or irregular terrain it gives you a real workout. Steering brakes would have been a good thing.
MarkV
/ Steering a DR brush mower #6
Hey Mike,
They're way outta my price range as well, but I still have them because I buy used. I bought an 850 with two tiller boxes and a finish mower for $1300 off craigslist and put 200 in parts in it. I sold the spare tiller and mower for $600. I then bought a rough-cut mower for 200 bucks and put another 300 bucks in parts into it. I have $1400 in the unit so far. I'm gonna buy a new Kohler Diesel by spring to mount on it. That'll be a new purchase for 1700. I'll have a $5750 machine for $3100 if I buy the Diesel.
You just gotta have patience and prowl craigslist for a couple months.
Here's an example - BCS 850 & Trailer $1800
/ Steering a DR brush mower #8
MarkV
Sounds like a weed whacker would/might be easier. ;)
/ Steering a DR brush mower #9
Another point for a good used Gravely built from the 80s to early 2000s. They could have steering brakes added to them at the factory or as an add-on kit.:D And anywhere from 8HP up to a 16HP Briggs Vanguard V twin. If you want to see brush fly, put a 30" deck on a 16HP Kohler single or B&S twin powered Gravely 2-wheeler. Just watch out for your prized small trees.;)
I went ahead and ordered one Tuesday so it looks like I'll find out for myself what it's like. I'm thinking a lawn mower on steroids for so long it's got a bit of roid rage going on. We'll see.
/ Steering a DR brush mower #11
Do post back your results.
I havent ran a DR, but have ran a Billygoat a few times. It WORE me out... I was mowing larger brush though. Steering brakes would go a long way, plus more weight and diff lock.
Im keeping my eye open for a BCS. WAY better quality and its a heaver, multipurpose machine with steering brakes.
One good thing about DR is their return policy if your not satisfied so its a no lose situation. Good luck with your purchase.
It should be pretty interesting. I agree about the BCS. I'd love to have the model with the brakes, but I gotta do what I gotta do within my budget. I've been scoping out Craigslist for BCS and Gravely, but haven't seen anything I wanted to get.
/ Steering a DR brush mower #13
I have the DR 17 HP 30" brush mower. It does have a locking differential that I use to get out of muddy spots. Its not hard to maneuver, its not for a little old lady like in their videos.
I wish I had bought the 17 HP in the 24" though, although the 30" is nice for cutting tall grass and cutting down 3" thick saplings.
Its the yard tool that I have used more than any other, good stuff. I have the chipper attachment too.
I picked up my 15hp machine today. Went to the freight depot and brought the crate home on a 5x9 trailer. My daughter helped me uncrate it. Put in some oil, gas and cranked it up. Chugged it down the ramp and we attached the deck. Parked it in the shed in the back. I'll have to wait until next week for the chipper attachment to show up. I got the 24" deck and am glad I did. I don't know if I could have squeezed it into the shed if the deck was another 6" wider. Going through the gate might have been a problem too. It was a short trip to the shed, but I found the machine well balanced and easy to turn. Real test will be the trip out to the property and mowing about an acre of brambles and scotch broom on a hill. Then we'll see how easy I think it is:)
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
Rake Mini Excavator Attachment (A61572)
Rake Mini...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
