Steak cooking methods
/ Steak cooking methods #61
As far as resting, etc. Each and everyone of us has their methods. There is no right or wrong way to cook a steak.... well...... We will have to agree to disagree. I will say this. My step son is a chef, degree'd, years of experience, etc. After I prepared a $200+ Prime Rib roast on our charcoal grill, he told me he "was never doing the Christmas roast again. That's all on you now". This was a few years ago.....
/ Steak cooking methods #62
There is always a pile of juice on my plate. When I cut the steak open, juice runs out.
Leave the same good tender piece of delicious meat on the plate for 20 minutes and come back to it, its like a totally different steak.
I don't think anyone lets a steak rest 20 minutes. It would be cold.
5 minutes is plenty of resting time.
/ Steak cooking methods #63
And in that 5 min time, your lovely steak just got cold....... No need I tell you.
/ Steak cooking methods #64
That simply isn’t true. It takes more than 5 minutes for a steak to get cold, though I don't let mine rest that long.
This is honestly the first time ever that I’ve seen someone suggest that resting meat after cooking isn’t necessary. If I’m not mistaken, Alton Brown even did a segment on it.
/ Steak cooking methods #65
I think I would know if it was cold.
No, it doesn't get cold in 5 minutes. I wouldn't do it, if it did.
It doesn't even get cold before I finish eating it.
/ Steak cooking methods #66
Something else that is not recommended...taking a steak off the grill right onto a cold plate...the plate should be close to the outside temp of the steak...IMO...
/ Steak cooking methods #68
It takes me about 10-15 minutes to eat a plate full of food. So every bite of steak eaten after about half way through has rested. I don't notice the last bites being any better than the first
/ Steak cooking methods #69
Just chunk the steak up into bite sized pieces, poke a green stick into them and hold them over hot wood coals till done as you like. Do it one chunk at a time so your eating a hot one and brazing the next one.
As for the "resting" time on your Palate will do just fine.
If your using quality meat it don't need marinades or sauce.
/ Steak cooking methods #70
Once ate at a steakhouse with a alternate, although similar method. They brought your steak out off the grill - been on just barely long enough to get stripes. Along with the steak was a slab of polished granite? approx. 2" thick x maybe 8" x 8". Stone slab was very hot. Cut off and cook every bite to your taste with last bite as hot as the first. A little different, but very good steak somewhere in Savannah, GA.
/ Steak cooking methods #71
Clearly, you don't get it, and don't want to. I got it.
/ Steak cooking methods #72
Maybe not. I have ate steaks that have sat, and ate them fresh. I prefer fresh.
Whenever grilling steaks at my parents or the in-laws, its more formal....pull the steaks off and cover with foil and place on the table. They sit there for 5 minutes or so while everyone is making their plate. It's "rude" to dig right in.
At my house, the plates are made and the steaks are pulled off the grill when everyone is actually ready to dig in.
I like fresh.
/ Steak cooking methods #73
As long as folks are happy with the way their steaks turn out...everybody's happy (but the steer)...!
I do have a suggestion for anyone that does not let their steaks sit for just a minute or two (depending on how thick it is) before cutting...give it a shot...I usually add a tab of butter on top and by the times it's melted it's ready (I prefer thicker steaks)...
FWIW...previously frozen meat will not re-absorb as much of the moisture cooking brings out...a fresh (never frozen) steak should re-absorb 75%+ of the moisture as the temperature of the "resting" meat equalizes... some juice should seep out during the process but not much after cutting, the meat will just be "juicier"...!
BTW...IMO It doesn't get much better than sopping up roast beast juice with a chunk of bread etc...
/ Steak cooking methods #74
I have never much cared for NY strip.
Only time I will eat NY strip, is at red-lobster. And they have a NY strip that rivals what I can do on the grill with a ribeye. Dont know if its just my local red-lobster or if it is actually a strip steak as they have it listed.....but its taste and tenderness is that of ribeye. Everywhere else I have ever tried strip, and even at home, I cannot even come close to the flavor and tenderness of ribeye.
As to potatoes....we do that all the time in the coals. Straight from the garden usually, knock the dirt off, smear butter all over the skin, wrap in foil and burry in coals for ~20 min.
Do the same thing with corn too, only no foil. Just leave it in the husk, and thow them on a bed of coals, use the shovel and cover with coals. Depending on how hot your coals are, ~8-10 minutes and you'll have some of the best corn ever
I hate reading these threads first thing in the morning:mur:
Lost any interest dining at Red Lobster after last Sunday's football game half time show.
/ Steak cooking methods #75
That's interesting that you should say that. When I built a table for my BGE, I bought a piece of polished granite, 18" square and set it in the table below the Egg. I chose granite, because in doing some research on the heat tolerance of granite, I found a video of a fellow who took a piece of granite counter top, heated it up with a propane torch, and cooked a steak on it.
/ Steak cooking methods #76
My steak rests only while I take the time to slice a tomato and onion to eat with it. Often that is my whole meal. Simple.
/ Steak cooking methods #77
I take the steaks off the grill onto a platter, carry them into the house and set them on the table. By the time everyone gets to the table, gets their drinks, gets settled, etc... Then you load up your plate and by the time you dig in, the steak has sat for a close to 4-5 minutes and that's about all I'd like them to sit. ;)
/ Steak cooking methods #78
My steak has rested quite a bit while still on the hoof. :laughing: I have had steak that rested and steak that was right off of the grill, I like right off the grill. I like my steak fresh to, ageing is as stated somewhere above nothing more than rotting. I don't like rotting steak. If that is what you want that is fine with me, If it makes you happy why should it bother me? Go ahead and get everything ready and have steak for supper tonight, the way you like it, and enjoy. Ed
/ Steak cooking methods #80
The last bite of steak always tastes more moist to me, but it's from the little tears dripping on it. The last bite of a good grilled steak is like the last day of a vacation for me.
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
John Deere 145 Lawn Mower (A63116)
John Deere 145...
2022 Meridian 1375 Auger (A63116)
2022 Meridian 1375...
2002 SHOP 20' FLATBED GOOSENECK (A63569)
2002 SHOP 20'...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
