starting procedure for m6040
/ starting procedure for m6040 #1
pockets
m6040
on the kubota m6040 what is the starting procedure (no manual to be found) on the ignition switch there is is an off position, then a lightning stroke, then the next postion the dash lights come on and then the next is the start. Where is the glow plug indicator located and what position turns on the glow plugs ?
/ starting procedure for m6040 #2
Turn switch to "On" position (roughly straight up and down). If the coolant temp is too low the glow plug indicator (left center of dash, below 4wd indicator) will illuminate. Hold in "On" position until glow plug indicator goes out. Turn switch to start.
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
213324 (A64279)
213324 (A64279)
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
