starting procedure for m6040
/ starting procedure for m6040 #1
pockets
m6040
on the kubota m6040 what is the starting procedure (no manual to be found) on the ignition switch there is is an off position, then a lightning stroke, then the next postion the dash lights come on and then the next is the start. Where is the glow plug indicator located and what position turns on the glow plugs ?
/ starting procedure for m6040 #2
Turn switch to "On" position (roughly straight up and down). If the coolant temp is too low the glow plug indicator (left center of dash, below 4wd indicator) will illuminate. Hold in "On" position until glow plug indicator goes out. Turn switch to start.
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
