Snow Stacking snow with FEL
/ Stacking snow with FEL #1
SteveV
MA
Bota 2400
We picked up a quick 6 inches of snow on the Rt 495 belt of Massachusetts. It was classic wet heavy snow ball snow. The foot that fell at the begining of January is still underneath this new stuff making nice packed snow to ramp the front tires up for higher piles. /forums/images/graemlins/wink.gif SteveV /forums/images/graemlins/grin.gif
/ Stacking snow with FEL #2
I've been clearing snow for the last two days but have not had to go outside yet. It's been raining.
Egon
I'm pretty sure you're taking a swipe at your weather forecasters. I took a look at the Environment Canada site this morning to see what the storm was going to do when it left here, and they seemed to think rain. It seemed a little weird to me though since you have more colder air available closer than we have, and we got snow. /forums/images/graemlins/crazy.gif SteveV
/ Stacking snow with FEL #4
NICE PICTURE. why does your b2400 kook so much bigger than my b2400 /forums/images/graemlins/grin.gif
/ Stacking snow with FEL #5
It actually has been raining. Quite hard at times but There is snow forecast in the imediate future.
Egon
I was kind of thinking the opposite; your tires look like they're set wider than mine but the end of the axle is flush with the hub on mine so they can't go any further. Back when I use to live in Rochester NY, I can remember shoveling /forums/images/graemlins/frown.gif 4 inches off the driveway every morning for three weeks. In other words, your tractor has more experience! Shoveling is also a thing of the past! SteveV
/ Stacking snow with FEL #7
</font><font color="blue" class="small">( NICE PICTURE. why does your b2400 kook so much bigger than my b2400 /forums/images/graemlins/grin.gif )</font>
He must make his snow piles smaller than you do Frank! /forums/images/graemlins/tongue.gif
Bill in Pgh, PA
/ Stacking snow with FEL #8
I added a light duty extension for use with snow/mulch. More than doubles my bucket capacity. Also added a set of skids to keep the bucket 3/4 inch off the gravel. Works great and four bolts and it's off.
Ya know.......there's always one in a bunch that has to show off......make the rest of us feel kinda........but..real nice job on the bucket extension! What did you use for material thickness? If you had to do it again would you make it bigger, smaller or keep it the same? We have to know! SteveV /forums/images/graemlins/wink.gif
/ Stacking snow with FEL #10
We got maybe 4" yesterday in southern New Hampshire followed by rain on top of it. This was the heaviest snow I think I have ever handled with the BX2200 in terms of weight per bucket load. We have a 400' driveway, a trafic circle in front of the house, and a 3 car garage with enough room in front of it to park maybe 10 cars. A lot of blacktop.
This is the first time all season I have felt chilled to the bone when I finished and it was barely 32 degrees, not zero like it was a week ago. But it was a WET 32 degrees. /forums/images/graemlins/mad.gif
I had to take a shot of Grand Marnier as soon as I got in the house /forums/images/graemlins/grin.gif because of the raw weather. Nasty weather, this is what I call arthritis weather .
/ Stacking snow with FEL #11
Okay, a wet 32F seems cold. After a life of DRY -30F please just give me that wet cold 32F. The internal warmer upper is nice watever the temp.
A humid house is supposed to feel warmer than a dry house. Outside high humidity is alleged to be colder than low humidity.
I'm confused but have noticed that that the terrible cold wet humidity does not seem to require the same degree of warm clothes the dry cold does.
Egon
/ Stacking snow with FEL #12
Used steel that was just sitting around, doing nothing. I had a few chunks. was around 3/16" thick,, 18" X 48". So the extension added 18 inches out front and 18" high on the sides. Reinforced with 1 X 1" angle iron. Weighs less then 75 pounds (in guessing) so I can manuver it alone. I have two 4" wide skids on the botton to keep it off the gravel.
I'm not real good at welding, I can make it stick real good, but don't look too close at the bead. (Whadda ya want for nuttin????)
I don't think I would have made it any longer, since my dump height is now limited.
Helps alot since I have one area in the driveway that drifts badly. Can get 3 or 4 feet deep. Taking bigger bites make it much easier.
Works well for mulch too.
There's a reason for celebration here: I just got my Kubota skin applied (it wasn't immediately available with the new software)!!! It looks cool with its orange backrounds. The other thing that you provided is the ability to make the bucket bigger. One of the things i don't like about the stock Kubota design is the lack of rollback to flip things in the bucket. Your design doesn't necessarily have to extend the bucket parallel to the existing bottom but could be angled up to provide more rollback. An extension on the top edge would prevent material from falling back on the operator when fully elevated and rolled back. The bolt on side edges you used will allow this bottom angle to be changed. Good job, you just saved me from taking a more complicated path! SteveV /forums/images/graemlins/laugh.gif
/ Stacking snow with FEL #14
Skent, Yours is alot bigger than mine and I'm jealous. /forums/images/graemlins/frown.gif
Nice job with the enlargement.
/ Stacking snow with FEL #15
snow rules for tractor fun /forums/images/graemlins/cool.gif
/ Stacking snow with FEL #16
Great job skent -just about exactly what I have planned for a spring project. Just bought a torch set to cut the plate. Can't quite see in the picture - do your sides fit inside the stock bucket? I was thinking of match the sides against each other and using a strip of plate to extend inside for the bolt attachments. (I already have one hole for the bolt on toothbar and was going to add another on top) Also I was planning on extending by 12 inches as I was concerned about total lifting capacity being exceeded. Can you fill the bucket with snow/mulch and still lift with no problem?
/ Stacking snow with FEL #17
THAT MUST BE IT. /forums/images/graemlins/cool.gif just last week i had to fire up the beast to knock down the piles at end of drive so we could see when we were pulling out, then of course it got warm and rined and the piles would have gone down by mother nature. <font color="red"> </font> but what the heck seat time is seat time <font color="red"> </font>
/ Stacking snow with FEL #18
I added 18" and even with wet heavy snow there's no problem lifting. I have my extension overlapping inside the existing bucket sides. To test the bucket, I placed 10 bags of sand, (50 lbs each) and it worked fine. I think it would be impossible to load over that weight with snow, no matter how 'wet'.
We just got another foot of the light fluffy Buffalo snow on Friday. It made some really neat icicles on people's houses around here. Here in NE, we can't count that as real snow and life just goes on. Maybe next storm we'll get some of that sopping wet slop again! /forums/images/graemlins/tongue.gif Now I need a little picture of a flame here. SteveV
2022 EZ-GO ELITE...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
8'' PALLET FORK EXTENSIONS (A61572)
8'' PALLET FORK...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
