Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,738
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I purchased a set of SSQA adapters online that are the size pictured. I also purchased the SSQA plates for 3 different attachments. Everything fits as it should, there is about a 3/8" gap at the bottom as it should. The only issue I had was the springs that put pressure against the pins to hold the bucket in place were weak and I replaced them with OEM Bobcat springs and everything's works as it should.
I am curious as to why you think there should be a 3/8" gap. That would bother me and I would shim it. In my mind there should be no gap in any of 3 places (see arrows); between face of SSQA adapter and SSQA plate, between face of pin and SSQA plate slot, and between angled surface of SSQA plate and adapter for a proper fit.
gg
