Squealer or what?
/ Squealer or what? #1
northcreek2624
Lake View,N.Y.(WNY)
KIOTI DK40(2002)) Jacobsen 628D AWD Turfcat
I'm looking to put a 72" rotary cutter on my new 41hp tractor.I will be doing some commercial work,so I want to cut not wrench/weld if you know what I mean.
From what I've looked at so far the Bush Hog seems up to the task.I plan on getting the lam. tire,deflector and slip clutch.
If my thinking is wrong please straighten me out,it would be greatly appreciated...........Thanks, Mike
PS are there any places to buy on line and save $$...?
/ Squealer or what? #2
Don't know if this will work for you or not, but try checking across the border- with the U.S.- Canadian exchange rate being what it is you can possibly save quite a chunk of change. And if the implement is manufactured in the US or Canada there is no duty on it as long as there is not an engine on it. $ 1.00 Can= about $ .63US right now. Good luck.
/ Squealer or what?
HYDRAMAN, Funny you should mention it,but that's where/how I bought my tractor and saved a bundle,I guess it might work for a Bush Hog too............Thanks,Mike
/ Squealer or what? #4
I've had a squealer for about ten years I guess and if I had to do it again, I'd get a heavier model. The gearcase and hitch have been trouble free, but the rear part of the deck has been rewelded about 3 times now. Granted, I tend to run over anything and everything, but the deck just isn't heavy enough for more than just grass IMO. Bush hog builds good stuff, just get the heaviest model they have. You will be happier in the long run. HTH...
/ Squealer or what?
ScottAR,I thought the squealer was their heaviest model,am I missing something?..........Mike
/ Squealer or what? #6
squealer is their "light" duty ... go to www.bushhog.com -- I'm thinkin' you probably want at least their 280 series medium duty -- I was looking at the 285/286 when I ended up buying a woods 600 ---
mike
/ Squealer or what? #7
squealer is the light duty - I have a 5 footer I'm happy with but I don't do commerical or any real nasty stuff. I paid $900 new and the med duty was about $500 more than that. Good quick check is how much the unit weighs. In addition to heavier (100hp gear boxes) they use heavier guage metal for the whole unit which increases the weight a lot. Don't know how important the slip clutch is. I've been cutting for 3 years now and haven't sheared a bolt yet. The swinging design of the blades will absorb a LOT of the impact without transfering the torque to the drive shaft and the stumpjumper does apretty good job of keeping the rigid part from hitting anything. The problem with slip clutches that don't slip periodically is they can freeze/rust up.
/ Squealer or what? #8
I bought a used 5' squealer for $150 a couple of months ago. The drive train was in great shape and it came off a tractor with less than 400 hours on it. However, the deck of the mower is a mess. Every corner is broken, and the sides of the deck are bent every which way. I second the opinion that the deck is too light, but the rest of the unit is fine.
I just plan on reinforcing the deck with angle iron and welds when I get time. Until then, it's working fine, but it's ugly!
/ Squealer or what?
Thanks guys,I'm glad I asked, I'll check out the heavier BH units as well as the Woods units..........Mike
/ Squealer or what? #11
I'm pulling a BH Squealer 720 with my NH. While no major complaints after 18 months....other than small dents, I wish I had gotten a heavier unit now as most of what I am cutting when in brush is right at maximum this cutter is rated for. I have no doubt given what I do cut that the deck will get beaten up even more over time.
IndianaPaul
/ Squealer or what? #13
Just spent 2 days with our new Rhino SE_6. We almost bought a Squealer 6 ft but it didn't look like the deck was quite as thick as the Rhino. I ran some logs and a few chunks of metal through it I didnt see and it still looks brand new. It's only got about 8 hours on it though. I think the specs. are Rhino 10 ga. Squealer 11ga for the deck thickness.
Mike
/ Squealer or what? #14
Mike,
I have the Woods Brushbull 600 (medium duty). At a tad over 1000 pounds for a 60" cutter, it's pretty well built.
The one thing that stands out (in my opinion) on the Woods over the competition, is the method of holding the blades. You can change them after a hard season with just a wrench. Look into it and see for yourself, you'll be impressed.
Oh, I wouldn't think an online purchase would save too much as these dogs are heavy! But, who knows?
John Bud
/ Squealer or what?
John,Thanks for your input,I'll be sure to check out the Brush bull.I have a Woods mid-mount on my International,they make good stuff.......Mike
500 BBL FRAC TANK TRAILER (A65643)
500 BBL FRAC TANK...
Woodland Mills Sawmill (A65579)
Woodland Mills...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
1997 Peterbilt 379EXHD Day Cab w/ Wetline (A62613)
1997 Peterbilt...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2016 Polaris Ranger 570 (A62613)
2016 Polaris...
