rdsaustintx
Veteran Member
You're due for new fuel filters anyway. I don't know if you have 1 or 2 (the other BX's have 2). The bottom filter (right under middle of floorboard) on my BX is a tight fit, the other (near the injector manifold) is relatively easy.
You might consider ditching the cheap wire hose clamps and getting conventional band clamps. Easier on you and the fuel line.
Use a drop cloth. Gently clamp the tank line to avoid a major mess. Unless you're very fastidious you may get a diesel shampoo anyway. I did.
System is easy to bleed. Turn switch on and wait a minute or so. Couple of hiccups and it should smooth right out.
To elminate the seat switch, it can be easily jumped just to see if the problem stops.
Good luck,
Russell in Texas
Good luck,
Russell in Texas
