Sprayer Sprayer
/ Sprayer #1
RobS
Super Member
Goshen, IN
None!
I'm looking for some advice on a sprayer. Use is for Roundup along the gravel drive (750') and around the rest of the property. Mostly spot work, other than the edges of the drive.
I currently have a three gallon backpack, hand pump model which I do not care for. It's clumsy and doesn't hold enough.
It looks like my choices are a larger backpack, stand-alone electric pump/tank unit or three point unit in either electric or PTO pump. I found a stand-alone 15 gallon rig that I could carry in my FEL bucket and operate from my tractor seat. Seems like a decent option but before I commit I'd like to hear what others do.
Thanks in advance,
/ Sprayer #2
I'm mostly doing what you are and find the 15 gal unit about right. I've used it in the fel, made a rack clamped to the rops above the 3ph, now have it in the bed of my golf cart. 25 gal might be nice and don't cost that much more but w/ 15 I can manhandle it full if needed, etc.
I got a boom sprayer for it too and it's much more efficient than the spot sprayer when you have the occasion to use it, ie, driveways, etc. If you have interest in a boom, make sure you get checkvalves in the nozzles, you'd be amazed how much leaks out after shutting it off ... usually right where you don't want it.
/ Sprayer #3
That would work, I think. I mount my 15 gallon sprayer on top of my disc harrow, or sometimes my spring tooth cultivator. I strap it down with bungee cords. I have been thinking of carrying it in the bucket since I got the FEL.
/ Sprayer #4
Hey Rob -
I've got a Fimco 3point version from agri-supply. I spent a few bucks on quick couplers for it so I can easily break the setup down to fill the pump with anti-freeze for storage (reduces corrosion). I don't remember if it is the 55 or 60 gallon, but has break away boom & hand sprayer attachments. It worked great to spray herbicide that wiped out my clover infestation.
If you think you'll ever use it to spray product on your lawn/field - get the three point / pto version. Not terribly expensive - $750 when you factor in couplers, pump & shipping.
/ Sprayer
hazmat said:
Hey Rob -
... says the guy with the brand-spanking new tractor coming!!! Overall, I agree but I just don't see myself spraying large areas. Based on what I've read so far, I'm leaning towards a Fimco 30 gallon "economy" spot sprayer. It's more tank than I probably need but a higher output pump than the off-brand 15 gallon I saw. I'll have another look tomorrow and make a final decision.
Tanks to all for the input (yes, pun intended).
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2025 Kivel Quick Hitch Skid Steer Attachment (A61572)
2025 Kivel Quick...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
