Sprayer tank repair
/ Sprayer tank repair #1
cmyoung2
Platinum Member
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
40 Gal tank from TS. Not sure how old, but at least 4 years. Tank split on the seam above the drain, you can see it just below the label. How is the best way to repair? The split is about 1/2 way up the tank, about the 25 gal mark, only about 2-3 inches, but on the seam, and I usually only put in 20-25 gal. Replacement is ~$150 but shipping is another $170. New sprayer is $700. None of those options are good for a sprayer I use maybe 2-3 times a year, but when I need it I really need it. The tank cost I could stand, but not with the shipping.
  • IMG_4401 (1).jpg.pdf
/ Sprayer tank repair #2
IF tank is completely dry inside, you might try sealing it with a tube of silicone rubber (RTV) by coating over split from inside....
/ Sprayer tank repair #3
You could try that Flex Seal tape. It comes in a clear color and 6" width. I'd put a piece on the inside and outside. The guy on TV made a boat out of it so it should work.
Just so happens that I bought two 40 gallon sprayers this past summer. (Complete 3-point sprayers in great condition.) Found both on FB and paid $200 each. Long story why I ended up with two, but if you search often you'll be surprised what's out there.
/ Sprayer tank repair #4
What about trying a plastic welding tool. I have an attachment that goes on a Weller soldering iron that has served me well over the years!
/ Sprayer tank repair #5
/ Sprayer tank repair #6
Ever consider a new 20-25 gallon sprayer ? I have one purchased from Tractor Supply that only cost about what you quoted for shipping charges.
/ Sprayer tank repair #7
Check that out. Estimated delivery to my house is $20. Just another option. Still think you could also find a used sprayer cheap and swap out parts.
/ Sprayer tank repair #8
That $20 Harbor Freight soldering iron style plastic welder would work just fine for that HDPE tank, go slow as the tip is copper and is really soft and easy to break, let the heat do the work, don't force it... I would use the tip backward to open up the crack with the point then slowly heat it up with some of the filler rod it comes with until it is flush then probably cut a piece of the stainless mesh it comes with and push that in flush with the surface for strength.
/ Sprayer tank repair #9
Both local Farm and Ranch Supplies sell new poly tanks suitable for sprayers, for around $125. But this time of year, you might buy the complete sprayer on clearance for less. They only have a very limited space to hold things between seasons, and have very good end of season sales, if you have space to store things.
/ Sprayer tank repair #10
Typically cracking on older poly tanks is because they are UV degraded. Welding might or might not work. I'd try deflecting the plastic and see if it cracks away from the seam, before I wnet ot the trouble of trying to repair it.
/ Sprayer tank repair #11
Another option is to see if you can rework the frame to substitute a 50 gallon poly barrel. Poly barrels are about $10-20 around here. You'd need a fitting to adapt it which might cost another $10 or so.
With the cost of chemicals being so high, you wouldn't want the tank to split and dump chemicals out where you don't want them.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
UNUSED IRANCH 22" MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 22"...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2018 HINO SA (A58214)
