Chip doesn't have the primary clutch release fingers for the drive transmission (1st engagement) for the TS254c nor did he have any on order when I talked to him last week. He did have a clutch assembly on order that he thought would be in this week. At $500 for what will be 3 clutch release fingers I'm in a bit of sticker shock! The fingers are $15.95 but are 6 weeks to order and $150 air freight!
Does anyone know if you can leave out the 3 primary release fingers and put it back together to use until the replacement fingers arrive? That's basically how mine was operating anyway until the bearing self-destructed.
Also, I've been looking for a comparable replacement since I figured the chinese didn't completely invent that clutch design on their own. It looks to me if it might be designed after a Long tractor 11" clutch assembly built in Romania. Why the chinese wouldn't choose something with a better service record, such as a Massey-Furgeson 135, I haven't a clue. I'm trying to find a Long dealer now to compare measurements.
I'm also trying to figure out if I may be able to repair my clutch fingers. I doubt it but may try anyway. The outside frame steel is still intact, just badly bent so I may try to heat and straighten the steel, reforge it, and add weld some contact surface material to it.
If anyone has any experience doing this, I'd greatly appreciate your guidance.
Thanks all!
