speedco wood spliter
/ speedco wood spliter #1
chrisu
HI I bought a speedco wood spliter and used it for about a year now and it ran out of oil damm that stopped the motor I un sized the motor not the motor will spit and spuder and it will not stay running and there is gas coming out of the muffler I am hopeing to save the motor if anyone can help
/ speedco wood spliter #2
Check your compression. I will bet those cyl walls on that engine are scored.
nope it is good
/ speedco wood spliter #4
Is gas coming out of the exhaust when running, or when just sitting. If you let is sit, and the needle valve is stuck, gas could leak into the cyl and then to exhaust. There should be a gas cut off lever on that engine right by the choke lever.
yes when it is running the gas come out of the muffler
/ speedco wood spliter #6
Spitting, sputtering and gas running out sure sounds like a dirty/stuck needle valve to me also.
Harry K
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2008 New Holland T2420 (A62177)
2008 New Holland...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
