speedco wood spliter
/ speedco wood spliter #1
chrisu
HI I bought a speedco wood spliter and used it for about a year now and it ran out of oil damm that stopped the motor I un sized the motor not the motor will spit and spuder and it will not stay running and there is gas coming out of the muffler I am hopeing to save the motor if anyone can help
/ speedco wood spliter #2
Check your compression. I will bet those cyl walls on that engine are scored.
nope it is good
/ speedco wood spliter #4
Is gas coming out of the exhaust when running, or when just sitting. If you let is sit, and the needle valve is stuck, gas could leak into the cyl and then to exhaust. There should be a gas cut off lever on that engine right by the choke lever.
yes when it is running the gas come out of the muffler
/ speedco wood spliter #6
Spitting, sputtering and gas running out sure sounds like a dirty/stuck needle valve to me also.
Harry K
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2844 (A58376)
2844 (A58376)
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2020 FREIGHTLINER...
2015 John Deere 8270R (A64119)
2015 John Deere...
207275 (A52708)
207275 (A52708)
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
