speedco wood spliter
/ speedco wood spliter #1
chrisu
HI I bought a speedco wood spliter and used it for about a year now and it ran out of oil damm that stopped the motor I un sized the motor not the motor will spit and spuder and it will not stay running and there is gas coming out of the muffler I am hopeing to save the motor if anyone can help
/ speedco wood spliter #2
Check your compression. I will bet those cyl walls on that engine are scored.
nope it is good
/ speedco wood spliter #4
Is gas coming out of the exhaust when running, or when just sitting. If you let is sit, and the needle valve is stuck, gas could leak into the cyl and then to exhaust. There should be a gas cut off lever on that engine right by the choke lever.
yes when it is running the gas come out of the muffler
/ speedco wood spliter #6
Spitting, sputtering and gas running out sure sounds like a dirty/stuck needle valve to me also.
Harry K
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59911)
2005 KENWORTH T800...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2002 Hyster C330B Tandem Smooth Drum Roller (A61572)
2002 Hyster C330B...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
