Some TYM T224 observations.
   / Some TYM T224 observations. #1
JTKub
West Falls, NY
TYM T224
I'm hoping some other owners chime in with their thoughts and/or experiences and maybe others interested in TYM in general can gain some info.
I've only put about 4hrs on it at this point and have owned the machine for 9 days. My use included mowing and light material handling with the loader. Everything works great. I have taken the loader off and on to see how it goes and just today removed the 54" deck, possibly for the season. The process for both was pretty easy for a 55yr/old shaped like a bratwurst.
I think all the hard parts on the machine are very good. In typical Asian import fashion, the soft rubber bits and plastics are questionable. I had mentioned in my first thread that my machine had spent ~1.5yrs on display, mostly outside. It's a new leftover 2024 model year. The dealer had to replace the rubber floor mat because it was completely sun dried and cracked. They would have happily sold it to me this way had I not mentioned it. They ordered one and swapped it no problem. The seatbelt was rusted so bad, they replaced that as well (again, only after I mentioned it). Some of the dark grey plastic around the dash has light sun fading as well, but the integrity seems OK.
Having crawled all over and under the machine, I found some questionable cable and hose routing under the machine that could lead to problems down the road and I will address those as I can. I also found the rubber boot on the F-R pedal dampener to have some dry cracks on it already as well. I have some products that I use to protect and preserve rubber products, so I'm not too worried about these things. In many spots, bundles of hoses or wires are just bunched up and zip tied without being secured to anything.
I removed the lower dash cover to get a look at the battery, some of the "electronics" and the fuel/water separator. That pops off fairly easy after removing three 10mm bolts. To my surprise, it has an Interstate group 51 battery in it. I was expecting some no-name special. Maybe it had been changed, but it didn't appear to have been.
Something that is a major flaw is in the brake lamps. I believe "Tony's Tractor Adventure" channel had mentioned this issue. Because of the design of the brake lamps and the intensity of the incandescent bulbs in them, they get scorching hot. If you leave the tractor running with the parking brake set, the brake lights stay on and the housings/red lenses will surely melt if they stay lit for any length of time.
Anyway, I hope some of this helps and we can add to this as time goes on.
It's been pretty warm for September in my area. Around 80F. The only fluid cooling these machines have is the fan on the input of the hydrostat, which just blows on the hydrostat. The transaxle housing, cylinders and hydraulic circuit in general gets pretty warm to the touch in as little as 15-20min of light usage. I went to shoot the trans housing with my IR temp gun the other day to get a feel for it and the battery was out of it.. More to come on that.
The transaxle case on my TYM is aluminum and looks very similar in design/layout to the Kubota BXs I've seen.
The one good thing is the plastic cooling fan looks easy to replace. One cross-bolt to remove and slide the drive shaft forward, then two bolts hold the fan in place.
Out of the SCUTs I looked at, the only one I recall having a cooler for the hydraulic/hydrostat oil were the Mahindras.
Do any others come with a fluid cooler?
   / Some TYM T224 observations. #4
The JD 1-series have real oil coolers.
   / Some TYM T224 observations. #6
Appreciate the info. Rubber parts can last longer with a bit of silicone oil, but honestly most people don’t bother. Btw, does Mahindra have any SCUTs with an oil cooler? As far as I know, the Emax series that TYM supplied to Mahindra doesn’t have an oil cooler.
. ... does Mahindra have any SCUTs with an oil cooler? As far as I know, the Emax series that TYM supplied to Mahindra doesn’t have an oil cooler.
Their newer 1120 line has them from what I've seen.
In today's TYM adventures, I found my fuel/water separater near half full of water! When I had the lower dash panel removed the other day to see what kind of battery she had, I noticed the primary filter / water sep, what ever you want to call it, looked a bit murky, but I got side tracked and moved on to other things. It crossed my mind again today and I had a better look at it. Sure enough, the red bobber ring is all the way to the top!
I probably dumped an ounce or two of water out of it and it had sludge in the bottom and a brownish tinge I had to wipe out of the inside of the plastic bowl. I cleaned the filter element and housing real good with brake cleaner and reinstalled everything. I'll keep a closer eye on it now. When I bled it, it refilled with nothing but fuel thankfully. Here's before and after pics.
   / Some TYM T224 observations. #9
Hopefully that's still leftover from being outside on the dealer's lot. I would address the strong potential of water still being in the tank. If there's a low point drain, you could drain off any water, or if not convenient you could put a water absorbing snake in the tank for a few weeks.
Your previous post mentions high heat from brake light bulbs that can melt lenses... Swap them out with LED's. I replaced all of my tractor's incandescent bulbs with LED's years ago, saving 11.3 amps.
I'm going to keep a close eye on it. It's like a saddle bag fuel tank setup where there's a 3gal tank under each rear fender, then the two of them are connected at the bottoms with a 1" or so rubber hose.
Good call on using LED replacement lamps. I'll have to pop the lense off of one to see what bulbs they take. It might be in the manual too..
PNEUMATIC GREASE UNIT (A58216)
PNEUMATIC GREASE...
3 Forks (A56857)
3 Forks (A56857)
1700 (A58375)
1700 (A58375)
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
12' Container (A57149)
1607 (A57192)
1607 (A57192)
