Some TYM T224 observations.
/ Some TYM T224 observations. #1
JTKub
West Falls, NY
TYM T224
I'm hoping some other owners chime in with their thoughts and/or experiences and maybe others interested in TYM in general can gain some info.
I've only put about 4hrs on it at this point and have owned the machine for 9 days. My use included mowing and light material handling with the loader. Everything works great. I have taken the loader off and on to see how it goes and just today removed the 54" deck, possibly for the season. The process for both was pretty easy for a 55yr/old shaped like a bratwurst.
I think all the hard parts on the machine are very good. In typical Asian import fashion, the soft rubber bits and plastics are questionable. I had mentioned in my first thread that my machine had spent ~1.5yrs on display, mostly outside. It's a new leftover 2024 model year. The dealer had to replace the rubber floor mat because it was completely sun dried and cracked. They would have happily sold it to me this way had I not mentioned it. They ordered one and swapped it no problem. The seatbelt was rusted so bad, they replaced that as well (again, only after I mentioned it). Some of the dark grey plastic around the dash has light sun fading as well, but the integrity seems OK.
Having crawled all over and under the machine, I found some questionable cable and hose routing under the machine that could lead to problems down the road and I will address those as I can. I also found the rubber boot on the F-R pedal dampener to have some dry cracks on it already as well. I have some products that I use to protect and preserve rubber products, so I'm not too worried about these things. In many spots, bundles of hoses or wires are just bunched up and zip tied without being secured to anything.
I removed the lower dash cover to get a look at the battery, some of the "electronics" and the fuel/water separator. That pops off fairly easy after removing three 10mm bolts. To my surprise, it has an Interstate group 51 battery in it. I was expecting some no-name special. Maybe it had been changed, but it didn't appear to have been.
Something that is a major flaw is in the brake lamps. I believe "Tony's Tractor Adventure" channel had mentioned this issue. Because of the design of the brake lamps and the intensity of the incandescent bulbs in them, they get scorching hot. If you leave the tractor running with the parking brake set, the brake lights stay on and the housings/red lenses will surely melt if they stay lit for any length of time.
Anyway, I hope some of this helps and we can add to this as time goes on.
It's been pretty warm for September in my area. Around 80F. The only fluid cooling these machines have is the fan on the input of the hydrostat, which just blows on the hydrostat. The transaxle housing, cylinders and hydraulic circuit in general gets pretty warm to the touch in as little as 15-20min of light usage. I went to shoot the trans housing with my IR temp gun the other day to get a feel for it and the battery was out of it.. More to come on that.
The transaxle case on my TYM is aluminum and looks very similar in design/layout to the Kubota BXs I've seen.
The one good thing is the plastic cooling fan looks easy to replace. One cross-bolt to remove and slide the drive shaft forward, then two bolts hold the fan in place.
Out of the SCUTs I looked at, the only one I recall having a cooler for the hydraulic/hydrostat oil were the Mahindras.
Do any others come with a fluid cooler?
/ Some TYM T224 observations. #4
The JD 1-series have real oil coolers.
/ Some TYM T224 observations. #6
Appreciate the info. Rubber parts can last longer with a bit of silicone oil, but honestly most people don’t bother. Btw, does Mahindra have any SCUTs with an oil cooler? As far as I know, the Emax series that TYM supplied to Mahindra doesn’t have an oil cooler.
. ... does Mahindra have any SCUTs with an oil cooler? As far as I know, the Emax series that TYM supplied to Mahindra doesn’t have an oil cooler.
Their newer 1120 line has them from what I've seen.
In today's TYM adventures, I found my fuel/water separater near half full of water! When I had the lower dash panel removed the other day to see what kind of battery she had, I noticed the primary filter / water sep, what ever you want to call it, looked a bit murky, but I got side tracked and moved on to other things. It crossed my mind again today and I had a better look at it. Sure enough, the red bobber ring is all the way to the top!
I probably dumped an ounce or two of water out of it and it had sludge in the bottom and a brownish tinge I had to wipe out of the inside of the plastic bowl. I cleaned the filter element and housing real good with brake cleaner and reinstalled everything. I'll keep a closer eye on it now. When I bled it, it refilled with nothing but fuel thankfully. Here's before and after pics.
/ Some TYM T224 observations. #9
Hopefully that's still leftover from being outside on the dealer's lot. I would address the strong potential of water still being in the tank. If there's a low point drain, you could drain off any water, or if not convenient you could put a water absorbing snake in the tank for a few weeks.
Your previous post mentions high heat from brake light bulbs that can melt lenses... Swap them out with LED's. I replaced all of my tractor's incandescent bulbs with LED's years ago, saving 11.3 amps.
I'm going to keep a close eye on it. It's like a saddle bag fuel tank setup where there's a 3gal tank under each rear fender, then the two of them are connected at the bottoms with a 1" or so rubber hose.
Good call on using LED replacement lamps. I'll have to pop the lense off of one to see what bulbs they take. It might be in the manual too..
/ Some TYM T224 observations. #11
RjCorazza, Is it as simple as it sounds? Just swap the bulbs? Led's bulbs vice the incandescent bulbs?
If it's that simple I'll swap out all of my lights! Including headlights. But - it just sounds too simple! Nothing ever comes easy for me. I don't want to cut wires, change plug ends, or anything that's working fine as is.
The bulbs themselves are direct fit, plug-n-play these days. Just get the part number off the incandescent lamps and search for LED replacements for them.
Some late model cars/trucks won't play nice with certain LED retrofits because of the vehicle's computerized controls, but with our tractors, this wouldn't be an issue.
/ Some TYM T224 observations. #13
My last 2 tractors and truck were a simple swap to the led equivalent base. The exception was the headlights on the tractor, where it was a little difficult to confirm the base type. I ended up comparing pictures and measuring the height of the replacement headlights. The led headlights I selected were somewhat underwhelming in light output, but I rely on much brighter cab mounted led flood / spots on the tractor.
I also matched the led color to the lens color, which supposedly results in more light output. Don't know if that's really true though.
To mitigate the potential heat issue, I swapped out the brake and marker lamps on my T224 with LED equivalents off the Amazon machine. The OEM brake lamp bulbs are 1156's and the markers are 6418's. Just search for LED equivalents for those. It came to about $14 shipped for the 4 lamps. The ones I ordered came direct from Amazon and they came next day.
/ Some TYM T224 observations. #15
What is the overall width of the T224? We're looking for a small tractor for difficult-access gardens and chicken coops and I've been considering the T224 or the T254. The overall width of those two as quoted in 100% of the sources I've found on the web seem to come right out of the TYM brochure but the TYM dealer gave me a different number for the T254. I'd go measure them myself but he's 100 miles away...
What is the overall width of the T224? ....
It's about 44" from outside edge to outside edge of the tires. The widest part is the guards around the lights on the ROPS. From edge to edge of those is about 53".
/ Some TYM T224 observations. #17
Sweet, thanks. That matches their literature (tires value). That's an impressive light setup. Lucky for us I think that the typical "will it fit" is below the knee for the most part.
I wonder why the dealer guy said 48" :confused:
The LED flood lights on the ROPS are very useful, but a bit odd in that each is controlled by their own toggle switch on the back of each housing. They're fed power any time the ignition is on. The other space of fitment concern with the T224 or RK21 can be height of the ROPS. It makes the setup ~7'3" tall. I believe it's designed at this height to accommodate the back hoe attachment.
/ Some TYM T224 observations. #19
What's your top-of-head height on the tractor? Like, how high of a branch could you drive under, if the ROPS is folded down, without ducking? (I'll likely go to the nearby dealer in the next week or so...)
/ Some TYM T224 observations. #20
I wonder if he was taking the bucket into consideration? It is 48"
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
John Deere 5M Series Tractor Loader Frames (A65640)
John Deere 5M...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
LANDPRIDE RCR1872 - 6' ROTARY MOWER (A64277)
LANDPRIDE RCR1872...
2015 International WorkStar 7500 Side Loader Garbage Truck (A64194)
2015 International...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
